First post, by Dimitris1980
I have this "error creating configuration file" problem in many sierra on line games. I unzip the games (zip files) through my windows 95 and then i run them in dos but i have this problem. I want to change the sound cards settings for instance (to use the Roland MT32) but the changes cannot be saved.
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower (x2), Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Reply 1 of 3, by jesolo
Where are the files extracted from?
Just check the attributes of the resource.cfg file and make sure it's not read-only.
Reply 2 of 3, by Dimitris1980
That was the solution. Thank you very much.
- Cyrix 120
- Atari 1040 STF
Reply 3 of 3, by CrossBow777
I've seen this if you just copy the CD-rom versions of the games onto a HDD directly since the contents on the CD-Rom are in read only mode to begin with.
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
