First post, by feipoa
I have a SCSI-based system which only provides int13 support up to 8 GB, but Windows 98SE sees the whole hard drive and all its partitions. Because my Windows 98SE partition is only 4 GB, I have elected to install the games into another partition, which is my W2K NTFS partition. I'm using Paragon's NTFS for Windows 98 to read/write to NTFS partitions from within Windows 98SE, but for some reason the wizard installers for various games only see approximately 2 GB of the 22 GB partition. Once that 2 GB is filled up, the installers claim that there is insufficient disk space to install and need to be exited, although Windows Explorer from within Winows 98SE can see the full 22 GB and the correct available space, which is around 18 GB.
For games which do not need the installer to register the installation in some way, perhaps via the registry, I can simply copy/paste the game files over, but for many games, they will not run properly if I do this.
Any ideas on how to bypass this HDD available space check during the installation wizard process?
Reply 1 of 5, by DNSDies
One way is to fill up the unused space on the drive with dummy files. just make 40x500+mb CD ISO files and put them on the drive to take up space. I've had that work before.
Reply 2 of 5, by cyclone3d
Sounds to me like the Paragon NTFS driver/utility has a bug in it.
What happens if you try to install these games that have issues on a large FAT32 partition that has at least 2GB already used?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 5, by jmarsh
It might be that the games are using signed 32-bit values to calculate the free space, so having between 18-20GB free would map to negative values.
Reply 5 of 5, by feipoa
jmarsh wrote on 2020-03-12, 20:14:
It only seems to be a problem when trying to install to NTFS partitions from within Win98SE though. I cut down my W2K NTFS extended partition and made another extended partition that is FAT32 and I've not yet run into the 'hard drive full error' when installing here.
