First post, by spark2k06
Click&Play (now Easy7zPortable) allows carrying out portable executables in a simple way, perfect for integrating with emulators. Binary, source and documentation available in my GitHub repository:
Your efforts are appreciated, I suppose, but you know Klik & Play is already the name for an old predecessor of Multimedia Fusion, right?
https://en.wikipedia.org/wiki/Clickteam
What exactly does the tool? From the sparse description and screenshots, it seems to create a self-extracting .exe file, which automatically runs the extracted program afterwards..? If that is the case, WinZip can do that since the very beginning.
Jorpho wrote on 2020-04-09, 16:18:Your efforts are appreciated, I suppose, but you know Klik & Play is already the name for an old predecessor of Multimedia Fusion, right?
I didn't know the name existed and it's commercial. I have no problem changing the name if this is a problem, it's just a free non-profit tool. What's more, I will.
I'll name it as Easy7Zportable, for example.
derSammler wrote on 2020-04-09, 16:23:What exactly does the tool? From the sparse description and screenshots, it seems to create a self-extracting .exe file, which automatically runs the extracted program afterwards..? If that is the case, WinZip can do that since the very beginning.
Sure, it does just that using 7z self-extractor instead of Zip. But this tool facilitates the process to add an icon, configure the decompression parameters and behavior of the self-extractor. In short, to carry out the process more intuitively ... but if you are not convinced, you can use Zip or 7z self-extractor on a regular basis. In addition, it was initially made considering its integration with DosBox, allowing it to be easily configured.
Specifically, the application is responsible for carrying out in a simple way all the following process described in the following link:
https://www.emezeta.com/articulos/crear-porta … es-sfx-avanzado
Use the Google translator for your understanding.
spark2k06 wrote on 2020-04-09, 17:08:Jorpho wrote on 2020-04-09, 16:18:Your efforts are appreciated, I suppose, but you know Klik & Play is already the name for an old predecessor of Multimedia Fusion, right?
https://en.wikipedia.org/wiki/ClickteamI didn't know the name existed and it's commercial. I have no problem changing the name if this is a problem, it's just a free non-profit tool. What's more, I will.
Done!
