First post, by spark2k06
Click&Play (now Easy7zPortable) allows carrying out portable executables in a simple way, perfect for integrating with emulators. Binary, source and documentation available in my GitHub repository:
https://github.com/spark2k06/Easy7zPortable
https://youtu.be/YJm4NRHPjTk
https://www.tindie.com/stores/spark2k06/
https://hackaday.io/spark2k06
Reply 1 of 5, by Jorpho
Your efforts are appreciated, I suppose, but you know Klik & Play is already the name for an old predecessor of Multimedia Fusion, right?
https://en.wikipedia.org/wiki/Clickteam
Reply 2 of 5, by derSammler
What exactly does the tool? From the sparse description and screenshots, it seems to create a self-extracting .exe file, which automatically runs the extracted program afterwards..? If that is the case, WinZip can do that since the very beginning.
Reply 3 of 5, by spark2k06
Jorpho wrote on 2020-04-09, 16:18:
I didn't know the name existed and it's commercial. I have no problem changing the name if this is a problem, it's just a free non-profit tool. What's more, I will.
I'll name it as Easy7Zportable, for example.
Reply 4 of 5, by spark2k06
derSammler wrote on 2020-04-09, 16:23:
Sure, it does just that using 7z self-extractor instead of Zip. But this tool facilitates the process to add an icon, configure the decompression parameters and behavior of the self-extractor. In short, to carry out the process more intuitively ... but if you are not convinced, you can use Zip or 7z self-extractor on a regular basis. In addition, it was initially made considering its integration with DosBox, allowing it to be easily configured.
Specifically, the application is responsible for carrying out in a simple way all the following process described in the following link:
https://www.emezeta.com/articulos/crear-porta … es-sfx-avanzado
Use the Google translator for your understanding.
Reply 5 of 5, by spark2k06
spark2k06 wrote on 2020-04-09, 17:08:
Done!
