First post, by Munx
So here is the story.
Some games, namely Doom, Duke3D and Quake run ok on a 5x85 build of mine when running in Windows. However when I restart into DOS mode, certain files become invisible and I am unable to launch these games.
First I though this was a bad CF card, so I switched to a new one. That didn't work, so I assumed the controller just didn't like CF cards, so I switched to a real hard drive, but I'm still getting the same problem. They are all formatted with a w98 startup disk into FAT16.
I forget which file Doom cannot find, but Quake gets an error "W_LoadWadFile: couldn't load GFX.wad", Duke 3D is "Could not find group file 'DUKE3D.GRP' ". Duk3ed will also start up just fine after installing the game, but will not find Duke3d.grp after a restart.
I had a similar issue quite a while ago with another 486 PC too, but I put that project to the side.
Can anyone advise me on what I'm doing wrong here? Maybe I did not set up the hard drive correctly?
243.89 KiB
289.39 KiB
My builds!
The Underdog - The budget K6
Reply 2 of 3, by Oetker
It looks like you're running the games from c:\windows, are you?
You should change to the games' directory first and run them from there. They're probably looking in the currently active directory (as opposed to the directory of their .exe file) for their resources.
Reply 3 of 3, by Munx
Oetker wrote on 2020-06-08, 11:37:
derSammler wrote on 2020-06-08, 11:37:
Try adding FILES=40 to config.sys
I'll try that, thanks
EDIT: OK, so changing to the games directory before launching it worked. Thanks a lot!
My builds!
