First post, by AlephZaku
After restarting from Windows 98 into MS-DOS, I've tried launching a few programs without success. After I enter the name of the executable and hit enter, I get a carriage return and a blinking cursor, but nothing happens otherwise, and the system becomes unresponsive, requiring me to hit CTRL+ALT+DEL to restart. Doom's setup program and I think DSDMA for the Yamaha card were the only things I've actually been able to run. I haven't used Windows 98 or DOS in a very long time so I'm unclear on how to resolve this -- any help would be appreciated.
PC:
Pentium 3 700MHz
NvIdia Geforce 2 MX (also tried this with an ATI Rage 128)
Aureal Vortex (also tried this with a Yamaha 744 though)
256 MB ram.
Autoexec.bat:
SET BLASTER=A220 I5 D3 T4
LH C:\WINDOWS\ASP4DOS.COM
LH C:\WINDOWS\SMARTDRV.EXE
Config.sys:
DOS=HIGH,UMB
FILES=40
BUFFERS=40
LASTDRIVE=H
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM
Reply 1 of 8, by Horun
Other than Doom you do not mention the DOS apps/games you are trying to launch. Do not think Doom "the original" will play nice off a P3 700 and run from Win98.
Reply 2 of 8, by Oetker
Unfortunately I can't exactly pinpoint the issue you're having, but try completely clearing your autoexec.bat/config.sys. DOS games like Doom and Duke3D that use DOS extenders don't need emm386 or himem; smartdrv can cause issues too.
On my P3, my autoexec.bat only contains the SET BLASTER line (Config.sys is empty), and then I have a batch file I run manually to start CuteMouse and UniSound.
Horun wrote on 2020-06-18, 04:34:
It'll work fine when rebooting to DOS, like he is.
Reply 3 of 8, by AlephZaku
So I could get a few actual programs to start. Here's a list of what I've tried that did and did not work. I cleared out my config.sys and autoexec.bat, and also restored BIOS settings to default and changed my CMOS battery.
Programs that fail to start:
Jazz Jackrabbit
Doom
Wing Commander 2
Wizardry 6
Alone in the Dark (I can get to the pre-game text mode configuration screen, but starting the game itself gives me a blinking cursor and nothing).
memmaker
The DOS setup program for the Yamaha 744 drivers
Univbe (I don't think you're supposed to manually run this anyway, but still)
Terminal Velocity setup program
Programs that worked (the handful of games I can get working all run fine for what it's worth):
Zeliard
The Bard's Tale
Duke Nukem 2
Doom setup program
Jazz Jackrabbit setup program
Throttle
Oetker wrote on 2020-06-18, 06:48:
It's failing to start in DOS, but it actually works perfectly from Windows!
Reply 5 of 8, by AlephZaku
jmarsh wrote on 2020-06-18, 13:48:
Are you sure the HDD is properly configured in the BIOS?
I'm not!
Here's what the IDE section in the bios looks like:
IDE Controller: Both
Hard Disk Pre-Delay: 6 Seconds
Fixed Dist Boot Sector: Normal
Primary IDE Master [ST31200225A-(PM)]:
Type: Auto
Maximum Capacity: 65535 MB (Actual HDD size is 100gb, split into two 50gb partitions for what it's worth)
Multi-sector Transfers: 16 Sectors
LBA Mode Control: Enabled
Transfer Mode: FPIO 4 / DMA 2
Ultra DMA: Mode 2
Secondary IDE Master is the CD/DVD drive.
Reply 7 of 8, by AlephZaku
DosFreak wrote on 2020-06-18, 14:48:
Are you booting straight to DOS or starting Windows and then exiting to DOS?
The latter, and that seems to have been the problem. I got a shortcut to *actually* boot into DOS from Windows. Selecting Restart in MS-DOS mode from the shutdown menu is... doing something else, I take it?
