First post, by TelamonLivesOn
Hi, I currently have Blood 1.11 (The September 27th Build) without the plasma pak installed on a DOS 7.1 computer (this is likely not the issue due to it doing the same thing on 6.2). While the OPL3 MIDI works fine, the CD Audio will play but always fails to loop when I'm playing. The only way to "fix" this is to reload a save. I know there were DOSBOX problems with this, but there was no information regarding this issue in DOS. Is there some sort of TSR that can tell MSCDEX to loop cd audio or a patch that allows blood to reissue the play audio track command after each track is ended? This issue really breaks the experience for me. Please let me know if you have a solution. Thanks!
