First post, by JP32
So here is my system:
IBM PC 300 PL
Windows 98 se
Pentium 2 400mhz
192Mb ram
ATI rage 128GL (109-51900)
ISA PNP ESS ES1868F
+the usual floppy/cd/hdd drives
Anyway, everything works as I like it, I've had surprisingly little problems thus far, but since I have had no luck finding PC crt I decided to use my CRT TV via my graphics cards composite tv output, and its picture quality is surprisingly good, even win98 desktop is useable.
I have tested many games, like doom, duke 3d, jill of the jungle.. Everything works on my flat monitor (HP vs17), and on my CRT tv too(its generic Euro TV, it says schneider scenaro 145 on back, and I know vestel 11ak37's service manual works for it, dunno whats the original model).
Anyway, so far the only game where I have issue with the ATI's tv output is Rayman Gold, both the original and designer.
Heres video showing the issue: https://www.youtube.com/watch?v=Dd4GagfGxWo
I noticed that rayman runs at 59,3hz when I set frequency in-game to 60, and 49,6hz when its 50, I see that on my flat monitors information screen, and it seems like my CRT TV doesn't like neither of them, on 60 the screen jumps around like crazy, and on 50 its little more stable but it still bounces constantly, on my flat monitor the picture is fine.
I have tried setting the TV output to USA/NTSC, and Euro/PAL in ATI's settings but there is no difference. I tried to run the game via dosbox, and there it seems like it runs at "proper" 60hz or 50hz, but my PC isn't fast enough to run it via dosbox(it runs in slowmotion with 99% cpu usage 🤣), but the picture is stable on the tv output. I also have tired disabling the vga output and only have composite output, but it made no difference. I tried running the game directly from DOS, but it made no difference..
Is there any way to fix this? Force the game to run at 60hz or something?
