First post, by Muz
Terra Nova have some coloring issue in Toshiba Satellite 225CDS running Windows 98, what should I do?
104.75 KiB
117.54 KiB
Reply 1 of 9, by Hezus
If you're running it straight out of Windows 98, then exit Windows first and run it from the DOS prompt. This might help.
If I recall correctly, Terra Nova uses UNIVBE, so take a look here and try one of the solutions there.
Visit my YT Channel!
Reply 2 of 9, by Muz
If I turn UNIVBE off, the video and the game runs well, but the color for the menu, navigation are like 16-bit, like the above.
Okay, I've run the UNIVBE from the downloaded link, now when the screen is at 320 x 200, the screen looks like a vertical glass, but for 320 x 400, the screen looks normal.
100.95 KiB
111.68 KiB
110.62 KiB
Reply 4 of 9, by chuky
Does this happen with other games in 320*200 ? Did you try with an external monitor ? It looks like the laptop monitor does not upscale this resolution, or at least it displays a low resolution and puts black bars.
Reply 5 of 9, by leileilol
The readme's got advice about this happening on Matrox cards, which may also possibly apply here as it is the same phenomena
 2) If you have a Matrix MGA Millenium, run
Terra Nova WITHOUT INSTALLING UNIVBE and with
the +BADPALDAC switch.
long live PCem
Reply 6 of 9, by Garrett W
Terra Nova produces similar results with Voodoo 3 and I suppose Banshee and V4/V5 cards. I used the VESAFIX utility to alleviate this. Swaaye in the link above mentions that it might work on other, non 3dfx cards such as the GeForce FX 5950.
Reply 7 of 9, by Muz
Here are screenshots from the game when pressing print-screen in DOS...
34.98 KiB
43.99 KiB
43.99 KiB
43.99 KiB
102.35 KiB
Reply 8 of 9, by Muz
Garrett W wrote on 2022-12-15, 07:28:
Thanks for the VESAFIX suggestion, Terra Nova now looks nice in 320x200 for now...
89.15 KiB
