First post, by truemaster
hello. is there a way to play doom and doom 2 on win98se with accelerated 3d via an engine like doomsday on jdoom? but i also want midi playback i have an awe64 with masterpiece sf2.
my pc specks are 800mhz p3 and 512mb ram
Reply 1 of 4, by DosFreak
Sure without kernelex you can use the following:
DelphiDoom 2.0.6.729
Doom Legacy 1.48.8
prboom plus 2.5.1.4
Zdoom LE 2.8.1f
Zdoom32 2.8.6
If for some reason you really want to use Doomsday you can use v1.8.6, I don't recommend it.
For OpenGL you'll need at least a video card capable of OpenGL 1.2
If you don't want to limit yourself there are other ports that work with a software renderer only.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 4, by dondiego
I released ZDoom32 2.8.6a recently, the N executable runs on 98 but without the OpenGL renderer. I think ZDoom LE 2.8.3a ran on 98 with GL, 2.8.1f was for 95 and software only.
LZDoom, ZDoom32, ZDoom LE
RUDE (Doom)
Romero's Heresy II (Heretic)
