First post, by llm
hello.exe that should get executed by exeload.exe
hello.asm
.model small
.stack 200h
dseg segment 'DATA'
hello db 'hello',0dh,0ah,'$'
dseg ends
cseg segment 'CODE'
assume cs:cseg
start:
mov ax,dseg
mov ds,ax
mov dx,offset hello
mov ah,09h
int 21h
mov ax,4C00h
int 21h
cseg ends
end start
build with masm/uasm or wasm
exeload.asm
.model small
.stack 200h
dseg segment 'DATA'
filename db 'hello.exe',0
commandline db ' ',0dh
params:
dw 0 ; copy caller environment if 0
dw offset commandline
dw seg commandline
dw 0ffffh,0ffffh ; fcb1
dw 0ffffh,0ffffh ; fcb2
error_msg db 'exec failed$',0dh,0ah
dseg ends
cseg segment 'CODE'
assume cs:cseg
start:
mov ax,dseg
mov ds,ax
mov es,ax
mov dx,offset filename
mov bx,offset params
mov ax,4B00h
push ds ; save ds for return
push es ; save es for return
; seems to be needed for old dos versions
mov cs:[stk_seg],ss ; save stack seg and
mov cs:[stk_ptr],sp ; stack pointer in cseg
int 21h
jnc execute_ok
; ax = 8 = Insufficient memory
mov dx,offset error_msg
mov ah,09h
int 21h
jmp exit
execute_ok:
cli
mov ss,cs:[stk_seg]
mov sp,cs:[stk_ptr]
pop es
pop ds
sti
exit:
mov ax,4C00h
int 21h
stk_ptr dw 0
stk_seg dw 0
Show last 5 lines
cseg ends
end start
build with masm,uasm,wasm
the call to int 21h ah=4B00h returns with cf = 1 and ax = 8 => insufficent memory
i though exe program do not allocate the complete free ram like com programs - am im wrong - can find any references
Reply 1 of 12, by javispedro1
llm wrote on 2022-03-26, 09:53:
But only if the .exe does not request all the memory, and many linkers set it to request all the memory . See the value of the "Maximum allocation" in your .exe ( https://wiki.osdev.org/MZ ) , likely it is FFFF . I actually don't remember how to change this from MASM, I used to change it afterwards via EXEMOD or the like (but you can change it by hand for a test).
Reply 2 of 12, by llm
javispedro1 wrote on 2022-03-26, 11:57:
its seems that my MaxExtraParagraphs in the exe header is my problem
radare2-5.6.6-w64\bin\rabin2.exe -H output
"hello.exe"
ii 120 80
[0000:0000] Signature MZ
[0000:0002] BytesInLastBlock 0x0078
[0000:0004] BlocksInFile 0x0001
[0000:0006] NumRelocs 0x0001
[0000:0008] HeaderParagraphs 0x0005
[0000:000a] MinExtraParagraphs 0x0021
[0000:000c] MaxExtraParagraphs 0xffff <------
[0000:000e] InitialSs 0x0003
[0000:0010] InitialSp 0x0200
[0000:0012] Checksum 0x0000
[0000:0014] InitialIp 0x0000
[0000:0016] InitialCs 0x0000
[0000:0018] RelocTableOffset 0x0040
[0000:001a] OverlayNumber 0x0000
"exeload.exe"
ii 184 80
[0000:0002] BytesInLastBlock 0x00b8
[0000:0006] NumRelocs 0x0002
[0000:000e] InitialSs 0x0007
Reply 4 of 12, by Jo22
llm wrote on 2022-03-27, 06:23:
latest EXEMOD.EXE 4.02 from Microsoft C 5.1 (DOS only)
MS-DOS Player could be helpful then.
http://takeda-toshiya.my.coocan.jp/msdos/
latest EXEHDR.EXE 3.20 from Visual C++ 1.52c (runs also under Win64)
It likely is a Win32 CLI application then.
I think older versions of Visual C++ tools ran on Windows 3.1x Command Prompt, as well.
So they likely were DOS text-mode applications, maybe with an extra Win32 CLI stub, not sure.
Reply 5 of 12, by javispedro1
I remember MASM/LINK specifically has a command line argument to set the max allocation size to something else other than 0xFFFF. I also remember it's a command line argument, not a directive.
But I totally forgot the name of the flag 🙁
I always used later exemod since many linkers don't have this flag anyway. Cough, watcom.
Reply 6 of 12, by BloodyCactus
your com program that is doing the 4B needs to resize its memory with 4A, taking your stack into account.
eg:
mov sp,end_stack
mov ah,0x4a
mov bx,sp
shr bx,4
inc bx
int 0x21
;; last line in your code
resw 128 dw 0
end_stack:
Reply 7 of 12, by llm
javispedro1 wrote on 2022-04-15, 12:34:
im using exemod oder the -p- flag of UniLinker that sets the minimum in the header while linking
BloodyCactus wrote on 2022-04-15, 15:37:
i don't need further dynamic memory allocation in this case, so i think it is ok that the called program claims all memory until its exited
Reply 8 of 12, by BloodyCactus
llm wrote on 2022-04-16, 15:23:
no, your exeload needs to resize itself to its minimum it needs, so the rest of memory is free for dos to load your hello program.
Reply 9 of 12, by llm
BloodyCactus wrote on 2022-04-16, 17:07:
1. my problem is already solved since 2022-03-27
2. as i wrote: im using a linker command that reduces my minimum heap use in the exe header (so no need for modifiying my ram usage at runtime)
i can do also use EXEHDR.EXE or modify with int 21h/4Ah - but the linker is already doing the work for me
Reply 10 of 12, by BloodyCactus
llm wrote on 2022-04-16, 18:42:
the moment anything else touches that header your screwed (a packer, encryption, virus, anything that can mod the exe), you should always do it yourself than rely on magic in the header that is always manipulated by anything that wants to touch the header.
Reply 11 of 12, by javispedro1
BloodyCactus wrote on 2022-04-16, 21:08:
What magic in the header, this is the actual documented method. You might as well claim that "why use exe at all, a virus could corrupt it, we should all stay with com as god intended". 😁
Also, I had to look at the MASM manual so I found it: the corresponding MS LINK.EXE option is /CP (apparently an abbrv of "CPARMAXALLOC" . with that mnemonic, no wonder I can't remember it ) . For whomever finds this thread 😀
Reply 12 of 12, by llm
javispedro1 wrote on 2022-04-16, 22:23:
its also /CPARMAXALLOC for OptLink (from Digitalmars dmc/dmd) and -p- for UniLinker , watcom wlink does not support such an option
why should that - the microsoft linker and some others support it
and for example exepack (and other exe modifying tools) need to directly rely on the header field infos - no tool can ignore the header info or the result will not work correct
