First post, by NightShadowPT
I'm trying to make my boot as clean as possible and I'm using the Silent option (whenever available) when I install and configure my devices on Autoexec.bat and config.sys.
Nonetheless, not all of them seem to have the silent option and the verbose is displayed on screen.
On autoexec.bat I found that if I redirect the output to "null device" (using the ">nul" command after each line) I can avoid seeing the verbose, but on config sys I am not aware of anything similar I can do.
I am currently struggling with the CD-ROM SCSI device drivers from Adaptec:
ASPI7DOS.SYS
ASPICD.SYS
As I cannot seem to find the option to make them silent...
Any suggestions?
Thanks
Update: Corrected "console" to "null device" - thanks to analog_programmer for the correction.
NightShadowPT
Compaq Deskpro M 486/66 - 64MB Ram - Compaq QVision 1MB - Orpheus II Sound
Card - 4GB SCSI HDD + 4GB CF Card - SCSI CD-ROM Plextor PX-32TSi - Adaptec WideSCSI AHA-2740W - 3COM Etherlink III Card
Reply 1 of 7, by mattrock1988
Wow so I just had this same question I was asking myself when working on an old Windows 3.1 system.
I did some research and I found out what should be the solution, and I hope this helps!
There's a tool called "Blackout" which you can download from the simtel archive.
https://ftp.zx.net.nz/pub/archive/simtel.net/ … il/blackout.zip
From there, you extract the EXE to your location of choice, then invoke the file twice. Once towards the beginning of CONFIG.SYS as a DEVICE parameter, and again towards the end of your AUTOEXEC.BAT.
What the tool does is it blanks the screen while routines are carried out, then re-enables video output on the second execution of the tool.
Retro PC: Intel Pentium III @ 1 GHz, Intel SE440BX-2, 32 GB IDE DOM, 384 MB SDRAM, DVD-ROM, 1.44 MB floppy, Nvidia GeForce 4 Ti 4600 AGP, Creative SoundBlaster AWE64 Gold, Aureal Vortex 2
I only rely on 86box these days. My Pentium 3 PC died. 🙁
Reply 2 of 7, by NightShadowPT
Thanks for the tip.
Although blacking the screen was not exactly the option I was looking for, beggars can't be choosers 😁
To be honest I have not found any other options, so this will be a huge step in the right direction.
Thanks again.
NightShadowPT
Reply 3 of 7, by mattrock1988
No worries! Glad I could help.
Reply 4 of 7, by Malik
Out of topic, but :
I for one, love to see the outputs from my Autoexec.bat and Config.sys files. I do try to choose the minimal info switch as the parameter if available, if the output is too messy.
Reply 5 of 7, by Harry Potter
Well, I like both the splash screen and the verbose info. I sometimes used to press ESC during startup to display DOS's output. I also used to use XrX to change the splash screen. I have some C64 game screenshots as splash screens and can post a link if desired. I can also post a link to the XrX logo utilities and included splash screens, but they aren't mine. 😀
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 6 of 7, by analog_programmer
NightShadowPT wrote on 2022-10-14, 17:01:
On autoexec.bat I found that if I redirect the output to the console (using the ">nul" command after each line) I can avoid seeing the verbose, but on config sys I am not aware of anything similar I can do.
Let's make something clear: " > nul" doesn't redirects to "console", but to "null device", and thus you don't see the output on the monitor (console output). To redirect output to console (which you don't want) use " > con".
I've never tried " > nul" in "config.sys" and I had no idea that it doesn't work there, but it's the most simple and convenient solution for blackin' out the output from "autoexec.bat" commands.
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 7 of 7, by NightShadowPT
analog_programmer wrote on 2023-08-22, 03:43:
Indeed, you are absolutely correct.
I have updated my original post for accuracy.
Thanks
NightShadowPT
