First post, by Peter z80.eu
Hi,
I am desperately looking for an older Linux Antix version 14.4, filename is MX-14.4-non-pae.iso ( originally downloadable from https://downloads.sourceforge.net/MX-14.4-non-pae.iso - but not existing anymore ).
The current SF page for older versions https://sourceforge.net/projects/antix-linux/files/old/ does *NOT* contain any "non-PAE" version, especially not the MX-14.4-non-pae.iso , not sure why.
Does anybody knows where to get it (even a working Magnet/Torrent link would be fine) ?
Thanks in advance for any hint regarding this old, last non-PAE-Version of Antix
Peter
Reply 1 of 7, by mr.cat
Well, I may have found something...check it out:
https://web.archive.org/web/20161107094611/ht … .com/snapshots/
"October Update"? So perhaps this is actually a more recent one than the one you were looking for...
I couldn't test this myself (my connection is too slow), but the download starts so the iso seems to be there.
Reply 2 of 7, by Peter z80.eu
Unbelievable, but your archive.org Link does work, regardless of the file size (usually such big ISO files aren't captured).
Don't know the difference between the file without "October Update" and your referenced file, but it's definitely worth a try.
Reply 3 of 7, by mr.cat
That's weird cuz it works here, I've now managed to download the iso (boots just fine in qemu too).
You're right though it usually is the case that .isos aren't always preserved by archive.org.
However there's also this one:
http://it.mxrepo.com/Downloads/Snapshots/MX-1 … ae_Apr_2019.iso
That one boasts "non-pae" in its name, at least. EDIT: Looks like cmov is required for this version to boot.
Reply 5 of 7, by mr.cat
Peter z80.eu wrote on 2022-11-02, 22:46:
Did not find any hint about when the CMOVA (for example) instruction was introduced - does it exist since Pentium IV or later (Core Solo/Duo) or none of them, instead ... ?
Wikipedia says it was introduced with Pentium Pro. So P4 and Cores most probably have it too.
Reply 6 of 7, by Peter z80.eu
Thanks. "Pentium Pro and later (Pentium II and higher)" is usually called "686", "586" means usually Pentium (1) and above. These folks managing/dealing with the Linux distributions don't care about the filenames I guess.
Finally the enlightment came from this entry: https://lists.debian.org/debian-devel-announc … 5/msg00001.html
Reply 7 of 7, by acl
Just out of curiosity.
Why Antix ?
Is it because it's a live system ?
I used it a few times as a live CD system, to mirror disks over the network.
root@antix:~# cat /dev/hda | nc -l -p 8000
alex@desktop:~$ nc 10.0.0.10 8000 > disk.img
But I never installed it.
I have a Debian Potato installed on a 486DX4.
Works well. You can even install packages by the network using apt-get (software repositories are still up, as archive)
Doom on 486 Linux laptop is an usual experience.
«Story in a game is like a story in a porn movie. It's expected to be there, but it's not that important.» - John Carmack
