First post, by CraigAB69
- Newbie
I thought that I would share, and maybe people can add to this, information on Microsoft Lan Manager.
Books:
Microsoft LAN Manager : a programmer's guide
https://archive.org/details/microsoftlanmana0000ryan
The manuals for Lan Manager are located below, you will see "3+ Open". This is because MS partnered with 3Com see wiki: https://en.wikipedia.org/wiki/3%2BShare
https://archive.org/search?query=LAN+Manager
"Inside Windows NT", Helen Custer P.285 onwards.
https://archive.org/details/insidewindowsnt00cust/mode/2up
CDROMS:
Microsoft Developer Network 6 Winter 1993 (Or just search "Microsoft Developer 1993")
https://archive.org/details/Microsoft_Develop … k_6_Winter_1993
(I use Win 98 to view the MSDN CD's)
Printing (Print to PDF)
https://sourceforge.net/projects/pdfcreator/f … FCreator%200.8/
Web:
MS KB for Lan Manager (Also other KB's)
https://jeffpar.github.io/kbarchive/id/lanman/
Attached are docs that I created from the "Microsoft Developer Network 6 Winter 1993" CD.
Files:
If you are using MSDOS 6.22, use the EMM386.exe from c:\dos as the one in the LAMAN.DOS\DRIVER\DOSUTILS is older
MSDOS 6.22 = Version 4.49 120,926 05-31-94
LANMAN = Version 4.40 104,542 05-26-95
Changes on NT Server 3.51:
Control Panel -> Network Settings ->(Installed Network Software) Server -> Configure:
Check the box "Make Browser Broadcasts to LAN Manager 2.x Clients"
Hope this helps
Craig
“Wyrd bið ful āræd. Fate is inexorable.”
