First post, by Excelsior
Hello,
I have an old benchmark program which was made for Win95&Win98 but it can run on OSes as new as WinXP.
However it refuses to even install if I try on an OS as Windows Vista or newer (no matter if they are 32 bit or 64 bit OSes).
If I try with a VM the result is the same: either it won't install or it won't run if I succeed to install it.
Are there any other possibilities to make it run on Win7 or Win10?
If you wonder why is so important to make this old benchmark run on newer OSes is because this benchmark has a very comprehensive CPU test and I have already a database with results from a 486 DX4 (slowest Win95 I have) up until Q9650 (the fastest WinXP I have).
Thanks in advance!
