First post, by stanwebber
the example i know is ultima 7 with its proprietary voodoo memory manager (although with clever hacks it will now run under a windows command prompt).
i'm curious if there is a list of games (or known suspects memory manager-wise) that will only run under pure dos and not windows?
for that matter i remember ultima 7 was even problematic under dosbox for a period until compatibility was achieved. what games were the last holdouts for dosbox in this respect?
Reply 1 of 7, by leileilol
Windows 95's AppCompat keys (HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\MS-DOS Emulation\AppCompat\)'s a good start to look for games that Win95 strives to reboot into pure DOS mode for. Ultima VII definitely is featured there (among other Origin products).
long live PCem
Reply 2 of 7, by GunKneeNeon
I'm curious this too. After having tried a lot of games, I find some games which doesn't run well or at all in Windows.
Wings of Glory - This game needs EMS and won't run in Windows at all.
Screamer - It runs under Windows well, but the setup program needs real DOS.
Theme Hospital - This game runs under Windows without problem theoretically. However the intro video cannot be played in full screen mode and the MS-DOS prompt cannot be set to windowed mode to run the game. This leaves a black screen and you cannot start the actual game. So I have to go to pure DOS to play it.
All the other games I have tried so far runs well under MS-DOS mode.
EDIT: Adding Jill of the Jungle to the list.
Constantly looking for the driver for Acer Magic v1 MPEG decoding card.
Reply 3 of 7, by Joseph_Joestar
My memory is a bit hazy, but I think Jazz Jackrabbit can't work from within Windows. Aladdin also has some errors with either XMS or EMS when launched from Windows.
Reply 4 of 7, by Gmlb256
The Lost Vikings, runs within Windows, but music playback is slower than usual regardless of the driver used.
Reply 5 of 7, by Meatball
Crusader No Remorse
Crusader No Regret
Origin games to which leileilol alluded. Ultima VIII is probably on this list, also?
Reply 6 of 7, by Gmlb256
Remembered another one: Zone 66, which refuses to run when a XMS driver is present.
