First post, by KoniTec
Hi All
I have installed simcity 200o in dos 6.22, and it runs fine if the disc is in the CD Rom drive (as expected). However if i forget to put the disc in the drive, I get the message that the disc is missing from D: drive with the Abort, Retry, Fail, Ignore message, but i am unable to actually press any key for those options.
No matter what key i press nothing happens, even if i put the cd in the drive, and i have to hard reset the pc and start again.
Anyone know if this is a common issue, or if there is a fix for this?
Many thanks
KoniTec
