Reply 420 of 827, by copymaker
I am worry if here's correct place to ask. but I think it's quite related to Unisound.
I'm using two ISA cards on ISA slot. One is a Orpheus with PCMIDI and another one is a PCMIDI standalone card.
As CS MIDI on the Orpheus isn't used anymore, CS MIDI on Orpheus was turned completely off by EEPROM config tool, hence regarded as there are only two intelliegent MPUs existed in the evironment.
The PCMIDI on Orpheus, hereafter called PCMIDI1, has a X2GS daughter board jumper-set to IRQ3, P300.
The PCMIDI on PCMIDI card, hereafter called PCMIDI2, has a McCake daughter board jumper-set to IRC2, P330.
Both MPUs are identified correctly on MQDIAG with parameter a330, a300 respectably.
PCMIDI2 output (3.5 pi stereo jack) is connected to the line-in of Orpheus.
This is intentional setting to operate two daughter boards with bug-free MPUs and no cables for MIDI connection.
While PCMIDI1 always sounds correctly, PCMIDI2 is OK with many games I tested (ex. Budokan, SQ3, Willly Beamish, Beneath of Steel sky..) but problematic with some games (ex. DOTT, SAM&MAX, Tie fighter) mainly Lucas Arts' IMUSE engine. I can not tell those are everything. There may be more if more test done.
Anyway If I run the games, line-in of the Orpheus doesn't work, therefore I can hear no MIDI sound with the aforementioned games.
It doesn's seem a problem of the PCMIDI standalone card when I see an evidence that output of PCMIDI2 (3.5 stereo jack) sounds correctly all time even during playing the problematic games, too. Furthermore, once after trying to execute those games with the PCMIDI2, Line-in of Orpheus turned no sound from PCMIDI2.
The phenomenon is observed when Orpheus driven by Unisound driver but Orphinit, Re-initialization of the orpheus or reboot of McCake by SysEx message doesn't help. I had to cold boot a computer. I am very appreciated if someone help me out.
PS. Computer is
CPU: SS7 Pentium 90 Mhz (downclocked from 130Mhz)
Mobo : BCM VP1543 (ALI Alladin V, SS7)
VGA : Geforce 2 MX400 32MB AGP (No ISA IRQ allocated in BIOS)
RAM : 32MB SDRAM
HDD : SSD 8 GB
SOUND : Orpheus (A220, I7, D1) with PCMIDI_X2GS & PCMIDI standalone with McCake
etc: ACPI, IRQ3 & IRQ4 Serial port, Printer port disabled in BIOS.
Orpheus Driver : Unisound v.0.76f
