First post, by voima-tonna
Hi!
I received an MQX-32M MPU-card, but without the adapter cable, which turns the DB9-port of the midi card into two sets of MIDI IN/OUT -jacks. As it happens, I have a similar cable from some PCI M-Audio -card. Does anyone know right away if that cable works, or could someone provide a pinout for the MQX-32M card so I could check and possibly alter the cable accordingly. Thanks!
