Waveblaster Adaptor for IDE-HDD Swap Frames
First post, by Ulfenknulfen
Hello folks!
To make wavetable cards swappable, you convert a removable hard drive caddy with this board, to take a wavetable card. Then you hook it up with an IDE cable to the wavetable header on soundcard. Then you can pull the caddy out with the wavetable board in, and swap it over for another one, without opening your case, and possibly having to remove your soundcard also to do it, if access is tight.
An IDE cable is simply converted as a connection cable and my board is installed.
In addition, you can easily supply the wavetable card with power.,
Simply move the jumpers. I have ordered the first PCB´s and report here on further progress.
best regards
Paddy
P.S.
Thanks to BitWrangler for helping me to write the text clearly
🎵 Waveblaster Adaptor for IDE-HDD Swap Frames
🎧 Beepblaster 1.0, 2.0 Wavetable Module
🎶 Roland MT-32 Buffer overflow Hardware Fix
🕹️🖱️USB HID Devices on PS/2 and Gameport.
Reply 1 of 26, by Ulfenknulfen
Good News, everybody.
Version 1.4 is finished. It has a build in fan power regulator for the frame fan, and/or the caddy fan.
The PCBs have been ordered and are expecting delivery in the next few weeks.
best reagrds
Paddy
Reply 2 of 26, by gordon-creAtive.com
While I personally have no use for it, I love the idea and would love to see a picture of this in action.
Reply 3 of 26, by BitWrangler
Ditto... when I first saw it posted it took several reads through to realise what it did, so Ima mansplain it for others in case different phrasing helps ...
Reply 5 of 26, by BitWrangler
Yes you may.
However, trying to look up a good picture, I notice that a more common term for the device these days is "Hard drive mobile rack" for 3.5 to 5.25 inch drive bays. All the pictures I'm seeing are terrible, only show assembled unit, only found this tiny one (attached) to show people... So outer part, left, fits in a 5.25 drivebay, the middle part is where you normally install an IDE/PATA hard drive, but will be where this board goes, and the right part is the lid for that. Then the caddy/drawer/tray goes into the left rack part and connects with something like a centronics connector that is durable for many insertions. At the rear will be the standard 40 pin IDE header and power connectors.
Reply 6 of 26, by Ulfenknulfen
Hi @ all 😀
I´ve tested the first Editions of 'Waveblaster Devil Adaptor' and they are working well 😀
best regards
Paddy
Reply 7 of 26, by Pierre32
Dude, this is a really cool idea, and well executed!
I like having these mobile racks in a build. I guess you could even do a ghetto version of this by simply extending the cable into the drive bay, and having your WT board sitting in there loose. But I like all the functionality you've designed into that board.
Reply 8 of 26, by Ulfenknulfen
Hello Pierre32.
Thank you for your praise 😀
Of course you could have done the whole thing as a ghetto version,
but since you have to convert the connectors and cables (UDMA 80 to IDE 40-pin) anyway,
this is the much more elegant version.
best regards
Paddy
Reply 9 of 26, by GrafWasili
Sweet. You're working on some kind of front panel as well?
Reply 10 of 26, by RetroGamer4Ever
What would be really cool and useful for modern PCs is a PCIe x1 Waveblaster interface card. It wouldn't be hard to make one that fits the few old large boards and the newer small boards. The audio would be pure digital over the system bus, for the highest-quality.
Reply 11 of 26, by imi
that's quite the genius idea, I like it ^^
Reply 12 of 26, by Ulfenknulfen
GrafWasili wrote on 2022-03-24, 14:51:
Hi GrafWasili.
Yes. The Frontpanel is for using Serdashop WP32, but i can't test it, because I can't
buy CM4 Lite. There are all sold out - worldwide 🙁.
best regards
Paddy
Reply 13 of 26, by maxtherabbit
if only there was already a way to swap MIDI modules without opening the case... oh wait there is it's called MIDI cables
Reply 14 of 26, by Ulfenknulfen
maxtherabbit wrote on 2022-03-27, 13:14:
Right, and that's what it looks like.
I think the advantages should be clear to everyone:
* you have everything in the PC case
* Waveblaster sound card volume control works
* You don't need an external power supply
and it just looks cleaner. Sure, there are people who have something to complain about in everything.
best regards
Paddy
Reply 15 of 26, by dionb
It's not a matter of compaining, just of people with different priorities and different use-cases. I absolutely love this idea and massive kudos to you for doing it.
- but personally I won't be using it as I want to be able to share MIDI devices between multiple systems. For me, a patchbay and some Chillbox enclosures work better, particularly as I also have some external modules too.
One size doesn't fit all, but for people who want to use multiple waveblaster cards on a single system, this one comes pretty close 😀
Reply 16 of 26, by keropi
this looks a nice solution for someone that wants to do easy WT boards swapping
nice one!
will it go on sale?
Reply 17 of 26, by Ulfenknulfen
Hello keropi.
Thanks for your question.
I'm working on the final edition and inform you, when i'm ready 😉
best regards
Paddy
Reply 18 of 26, by Ulfenknulfen
Update :
The first Edition of the Final Product is on Ebay (Germany).
best regards
Paddy
Reply 19 of 26, by dreamblaster
Thanks Paddy for this great solution !!
I will add it in my test pc setup 😀
See it here with different cards installed
- X16L prototype
- XR385 - large card but it fits perfectly
also like the L/R stereo swap option
Thanks for your support !
