I have a Toshiba Satellite 335CDT and am having an odd bug with Wolf3D and Spear of Destiny with initializing Digital Sounds. When running them from Boot, I get everything except Digital Sounds. If I run Quake first, then I get Full Sound. Any help will be greatly appreciated.
Any idea on how to get them to initialize the driver without needing to run Quake first?
It could very well be that the other games are not initializing the sound correctly because they expect different default settings per @alexanrs
You need to:
1) Get into your BIOS and disable your printer (LPT1) port, which uses IRQ7 (change it to "Not Used.") This is through the TSETUP utility or by hitting ESCAPE and F1 at the boot splash screen.
2) While in the BIOS, change your sound card setting to the one that @alexanrs mentioned:
WSS I/O to 530
SBPro I/O to 220
IRQ to 7
WSS (Play) DMA to 0
WSS (Req) and SBPro DMA to 1
3) Save on the BIOS screen (press END and say "Y"es)
4) Boot back into Windows
5) Edit your C:\WINDOWS\AUTOEXEC.BAT or C:\WINDOWS\DOSSTART.BAT file and change the SET BLASTER line to: SET BLASTER=A220 I7 D1 P330 T6
6) Make sure SETUPSA /S is in the C:\WINDOWS\DOSSTART.BAT
If you get games that aren't working with sound, make sure your BLASTER variable is correct, try other games to initialize the sound card, or try different settings for the sound card. If you adjust the settings in BIOS, I've found that the Windows settings will change automatically, so really, you only will be having to change it in two places: the BIOS, and the SET BLASTER variable.
DOS Games are finicky sometimes, you'll have to play around to get certain ones to work correctly with sound.
* Edit: Also, try running SetupSA and make sure your volume levels are up on everything.
After troubleshooting a bit, I've determined that at least in my case, I needed to disable Printer Port (LPT1). Also Windows was trying to be helpful and was messing with the SET BLASTER variable.
