First post, by CHiLL72
Today I had a day off and I finally started going through the collection of (mostly ISA) soundcards I have collected over the past 15 years or so. Besides a whole box full of Creative Sound Blaster cards (ranging from SB 1.5 to SB AWE64) there were a few Aztech cards and also the card in the photos. I have never been able to find much useful information about it and I don't have any drivers, but I thought I'd put it in a PC and give it a go.
That was a bit of a mistake and it could have done some major damage.... The second I pressed the power button on my (perfectly fine) Intel BX system, there was a flash, a pop, a bit of fire, and some smoke. I turned off the power immediately and hoped that at least the card in the adjacent ISA slot had survived, because that was a Roland MPU-401/AT with a Roland SCB-7 attached to it. Fortunately, there was no damage, other than to the Viva soundcard. One of the small capacitors had given up and exploded, the one marked DC3 in the photo, which looked identical to ones marked DC1 and DC2 before the 'accident'.
Do you think this soundcard is worth salvaging? Does anyone have any useful information about it? Or is it worthless junk and I should throw it away?
If someone wants to rescue this card, please let me know. I'd be happy to send it to someone willing to fix it.
The attachment 20221115_151320.jpg is no longer available
The attachment 20221115_151327.jpg is no longer available
Most of the other soundcards I tested today were still fine and I will start selling off most of them, either through my webpage and/or Amibay.
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 1 of 4, by Tiido
This is some rebranded Aztech card from the looks of it. It should be a pretty good performer with above average sound quality. One of the tantalum capacitors exploded, the others will do so they need to get replaced. I personally would go for it, this shouldn't be a bad card by any means.
Reply 2 of 4, by RaiderOfLostVoodoo
CHiLL72 wrote on 2022-11-15, 21:56:
That card has a real OPL3 chip on it. So yeah, it is worth saving.
I would gladly take it.
It's an Aztech Sound Galaxy NX Pro.
It's one of those few cards with compatibility to Disney Sound Source.
Reply 3 of 4, by CHiLL72
Sent PM to RaiderOfLostVoodoo.
Reply 4 of 4, by appiah4
If Raider passes on it for whatever reason I'd also be willing to get it from you and fix it as well.
