DOS start up sound
First post, by wbahnassi
I'm wondering, if MS-DOS had a startup sound a la Windows 3.1/95/98...etc.. what would that be?
I'm thinking of adding one near the end of AUTOEXEC.BAT.. something that does both FM and a digital sound for example for ~1 second. Of course MS did quite some work to get Win95/Win98 startup sounds.. so for DOS it should really also sound well-thought, not cheezy.
Once I find a good sound I'll bake it into a tiny COM to run in AUTOEXEC.BAT.
Thoughts?
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 1 of 17, by Jo22
https://www.youtube.com/watch?v=EdHkYjv61D0
Just kidding!! 😂
No idea at the moment.
Maybe some melody, maybe of one of the early IBM systems (power on, error melody) if there's one ?
Or a tune derived from one of the MS-DOS commercials?
Edit: I *think* I've got something that fits your description.
It's from my early days of AdLib programming.
It's a short melody. I will search my backups, maybe I'll find it.
Reply 3 of 17, by wbahnassi
DosFreak wrote on 2022-12-20, 23:47:
The startup sound is when you turn on your computer.
The machine boots, beeps and drives seek. It's classic, but doesn't signify the OS as then you can have Windows 95 or 98 etc, which play something above that too. To me the beep and drive seeks are the signature of an IBM-compatible machine.. but I feel happy everytime I hear Windows 95 startup sound or Windows 98 kickass Take a Tour theme with the signature "ahhhh" 😅
I'm trying to imagine what MS-DOS would've had.. some Adlib-based chime and maybe a digital sound with it when possible.
Jo22 wrote on 2022-12-20, 22:44:
Or a tune derived from one of the MS-DOS commercials? […]
Hmmm I like the idea of deriving it from the commercial, esp. if we have Steve Balmer's voice ij the mix 😅 (but that wouldn't be professional though). Good luck with the search.. I have here code for a little DOS COM program that can play an Adlib dump from DOSBox. Once we find a good start up sound, I'll embed it in the program and put the COM file for others to enjoy 😁
Reply 5 of 17, by SSTV2
I would use exactly this as the startup sound on my ripened cheddar 😐
Reply 6 of 17, by Gmlb256
This would be a nice idea, a small program that simply makes a startup sound. Useful when putting it in AUTOEXEC.BAT after everything essential is initialized.
Reply 7 of 17, by leileilol
Usually the only sound is just the POST beep / memory tick and that varies by motherboard chipset.
In the DOS era though, the concept of a startup sound is a Macintosh thing and it'd probably be likely considered blasphemy.
Reply 8 of 17, by Jo22
What about MS-DOS compatibles? Did any of those have a startup chime, by any chance ? 🙂
Personally, the only thing I remember is the melody hidden in GEM 1.
If you click the GEM icon in about dialog, a melody plays.
Reply 9 of 17, by keenmaster486
"GEHHHH GEHH GUH - BEEP"
World's foremost 486 enjoyer.
Reply 10 of 17, by Stretch
I suggest the "Intel Inside" jingle.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 11 of 17, by polpo
In the early-mid 90s when I had an IBM PC/AT w/ Hercules graphics and a Gravis Ultrasound card plugged into a full stereo system with subwoofer (a rather mismatched setup), I had autoexec.bat play a CD quality WAV of the THX "Deep Note" when starting up because I thought it was hilarious that such a crappy looking computer would sound so awesome.
creator of PicoGUS and PicoIDE
Reply 13 of 17, by Jo22
Terminator theme.
Reply 15 of 17, by ahyeadude
I was inspired by this thread and started working on my own DOS 6.22 startup beautification...
https://imgur.com/a/quSpgkh
Be sure to turn up the sound
Reply 16 of 17, by Sphere478
ahyeadude wrote on 2023-08-27, 01:41:
What did you boot into?
Sphere's PCB projects.
