Reply 680 of 1438, by jtchip
vanfanel wrote on 2023-05-15, 09:26:Ah that's great to hear that the Linux code is there as a reference! I have copied this information to the issue I opened on the SBEMU git repo:
https://github.com/crazii/SBEMU/issues/16
OK, you might want to add a bit more information to the issue, lspci -nn shows the PCI IDs in addition to the name, /proc/asound/cards contains the list of audio devices, and /proc/asound/card0/codec#0 has codec information (though only as far as the node with the front audio output would be sufficient, it's quite long), repeat for each card.
