First post, by acl
Hi
I recently extended my retro interest to sound cards for DOS and i have some questions about upgrading my current setup.
I will soon receive my SC-55 and i'm preparing my setup for it.
It's a late Dos/Windows 95 system.
  • MMX233 downclocked to ~150Mhz (to help with speed sensitive games along with setmul)
  • PCPartner TXB820DS (Intel 430TX AT Board)
  • 32MB EDO
  • TsengLabs ET6100
  • Voodoo
  • Sound Blaster 16 CT2290
With some searchin, i read that the CT2290 was less severely affected by the hanging note bug.
That's a good point !
But also that in some situation, using digital audio along with MIDI could cause stutters / slowdowns.
And that a solution could be to use a second card for MIDI out for the SC-55.
Is my understanding correct to that point ?
I'm now looking for a card combination that could work with my constraints...
  • My case is really small and some tall ISA cards does not fit. Like AWE64s... i have several models and they are too tall and prevent the case to be closed correctly (and the case panel pushes against the card)
  • I would like to keep the feature set of the Sound Blaster 16 : SB 16 compat + real OPL3 (there are games which i prefer with OPL3 rather than wavetable synthesis)
  • Bug-free hardware MPU-401 implem
  • Preferably good compatibility an no TSR
  • MPU-401 intelligent mode is not required for my use
I came with a possibly viable solution (on the paper) :
  • Keeping my SoundBlaster 16
  • PLUS +
  • Adding an ES1868 AudioDrive i already own (have 2 or 3 cards with this chip)
Is that a correct combination ? Or am i missing something ?
Thank you very much
Reply 1 of 13, by Joseph_Joestar
The easiest solution would be to add one of your ES1868 cards to that system. As long as you configure both cards to use different resources, you won't have any problems.
You can use the ESS card for MPU-401 duties and the SB16 for the rest, if you so prefer. Additionally, some older "talkie" adventure games can benefit from the SBPro low-pass filter on the ESS card, if you like that kind of sound (I do).
My retro builds
Reply 2 of 13, by acl
Joseph_Joestar wrote on 2023-09-14, 10:28:
Thank you for your confirmation.
I reviewed the cards i already have and that i could use along the SB16 and this ESS one ticked most of the boxes.
I will definitely try the digital sound on it as well ! (This card is part of a lot i got this summer and i had no time since then to test anything)
Reply 3 of 13, by Shponglefan
I'm a bit confused as to the height requirements. You mention you have a SB16 CT2290 , which is a pretty big card, but an AWE64 won't fit? The AWE64 should be the same height as an SB16 CT2290.
Adding an ESS-based card would probably be fine.
Another option would be getting something like a Yamaha Audician 32 card, since they are quite compact, offer clean sound output, SB Pro compatibility, bug-free MIDI support, and genuine OPL.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 13, by acl
Shponglefan wrote on 2023-09-14, 15:54:
It's more the height above the ISA bracket that causes my problem.
It's a quite thin and compact desktop case :
The attachment case.jpg is no longer available
The attachment inside.jpg is no longer available
Once closed, if the card is too tall, then it can touch the case top panel... and since i'm putting a CRT over it, the weight is applied on the card PCB.
The attachment AWE64.jpg is no longer available
The attachment SB16-ESS.jpg is no longer available
Yes, i had the opportunity to buy one a few weeks ago... but i passed. (Even if it was not expensive, ~20€, i had no specific use for it)
Reply 5 of 13, by Shponglefan
acl wrote on 2023-09-14, 19:54:
Ah, understood. Yeah, the AWE64 has an extra 5mm of height to the PCB and I guess in your case that makes all the difference.
They're good cards. They can even be modded to replicate the original SB Pro low-pass filtering.
Reply 6 of 13, by stanwebber
als100 non-plus with a yamaha or unlicensed clone is probably what you want...could replace the sb16 entirely if you find a quiet one. they're not too hard to find. this one is up for sale right now for $25 buy it now:
The attachment s-l1600.jpg is no longer available
i run an ess688 with a yamaha opl3 which is similar to the als100 (except no sb16 compatibility) and very quiet; however, the mpu401 is emulated (tsr) so i don't know if you'd want to deal with that.
an aztech azt2320 is another option with an integrated yamaha opl3 and real mpu401. they are cheap, plentiful and excellent. the cut down revisions are the triangle shaped cards.
Reply 7 of 13, by acl
stanwebber wrote on 2023-09-15, 07:54:
als100 non-plus with a yamaha or unlicensed clone is probably what you want...could replace the sb16 entirely if you find a quie […]
I considered this card too after reading about it here (https://www.dosdays.co.uk/topics/Manufacturer … avancelogic.php)
But i don't currently have one (while i already have some ES1868 (at least 3 different models)). I will try the cards i have first... i already have too much things on storage 😁)
I have an ALS120 (which also provides a bug-free MPU-401 interface... but is worse than ALS100)
I'm also thinking about swapping the case and motherboard for a larger case and ATX Socket 7 board.
I got new ones after assembling this system.
That way i could use an AWE64 for 16bit sound and bugfree midi + Another OPL3 card (bugfree midi too). This would give me better flexibility.
Reply 8 of 13, by midicollector
I'd also recommend an ESS. I adore the ESS in my machine, but more importantly in this case, it works flawlessly with midi. The 1868 is an excellent choice, I have a 1888 which is only slightly different.
Reply 9 of 13, by acl
midicollector wrote on 2023-09-16, 20:27:
Thanks !
I will test this setup and update the post after testing... soon i hope. Not much free time lately
Reply 10 of 13, by acl
I ultimately made the choice of only keeping the ES1868.
It does not support 16 bit sound like SB16/AWE32/AWE64. But it's the only drawback.
The FM synthesis sounds really close to a real OPL3 (at least for me playing Dune).
This card ticks all the boxes otherwise. Compact, not trouble with MPU-401 (no hanging notes, no system slowdowns). I'm happy with it for the moment.
I understand why this card is getting some love.
Reply 11 of 13, by Joseph_Joestar
acl wrote on 2023-10-08, 14:00:
You can use its native AudioDrive mode for 16-bit sound in games which support that, like Heroes of Might and Magic 2 for example.
It's also possible to transplant AUDIODRV.DIG into other games which use the Miles Sound System, though not all games will work with it. I posted some instructions for that here.
Additionally, it might be fun to experiment with native/enhanced ESFM in games which support that. The results can be pretty interesting, if the implementation was handled well. More info here: ESFM details
My retro builds
Reply 12 of 13, by acl
Joseph_Joestar wrote on 2023-10-08, 14:07:
You can use its native AudioDrive mode for 16-bit sound in games which support that, like Heroes of Might and Magic 2 for exampl […]
Thanks !
I found a list of Miles Sound System games on vogonsdrivers. Not sure why it's hosted here since its not a driver
But I will give it a try if I want to play something in this list .
http://vogonsdrivers.com/getfile.php?fileid=30&menustate=0
Reply 13 of 13, by acl
I don't know what's happening with the output.
There is a jumper to disable the amplified output. But when it's "off" the sound is really crappy.
Muffled or filtered.
But with amplification I can't use headphones.
With amplification+ reduced volume in the mixer I'm picking a lot of noise.
The best I could do was to leave it amplified+ add a passive volume knob to turn the volume down for the headphones.
Do you know what could cause the muffled/filtered sound ?
