First post, by envagyok
Hy everyone.
I purchase a Terratec Profimedia 16/95 (sometimes called 16/96) sound card.
I download win9x driver from terratec website, it self extraxted to a directory.
After i install al of drivers, it has all with yellow mark at device manager, configmg.vxd error code2.
There is no irq or similar conflict.
I attach photos.
I want to try under Dos too, but i have no opinion how can i install it with Dos.
It's wavetable working under dos too?
Need some tsr to run?
Thanks any helping hints.
Reply 1 of 2, by envagyok
Reply 2 of 2, by envagyok
I make install under dos.
There is set up 220/5/1 for SB compability, and irq 2/9 io:330 for mpu-401
When i try with bundled software , 8, and 16bit sound output is ok, but the test with fm synthesis only 1-2 times has sound, mostly i dont hear sound.
I try with doom too, but no music with setting music device as general midi @330
No music with setting music device as Sound Blaster
The fx sound when i set up soundblaster mode, is good. So in game sounds like shoot, i hear.
Is this terratec maestro 16/96 card defect, or what problem occur?
Maybe isa bus speed?
I tried with p233 and prntium 3 650
