First post, by zuldan
Hi all, I currently have 2 audio cards (AWE64 and Gravis Ultrasound PnP) to install into 2 different machines, 1x MS-DOS (Pentium 233mmx) and 1x Windows 98 PC (Pentium III).
I can't decide which machine to use the Gravis Ultrasound on. I know for some DOS games, a patch is required for them to work with the PnP version but what are Windows 98 games like with the Gravis?
Reply 1 of 4, by dominusprog
Speaking of my personal experience, AWE64 is better suited for Windows. The synthesizer chip is awful and general midi doesn't work out of the box.
A-Trend ATC-5050 ❇ Pentium MMX @ 233MHz ❇ 64MiB SDR RAM (32MiBx2) ❇ A-Trend S3 ViRGE/DX 4MiB
Creative Vibra 16 ❇ BTC 1817DW OPTi 931 ❇ 20GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 4, by Gmlb256
Although CQM isn't faithful to the OPL3 FM synth and the EMU8K works better in Windows, I would pick the AWE64 over the GUS due to better Sound Blaster and AdLib compatibility. It still has an MPU-401 compatible interface that is accessible thru the gameport.
The best-case scenario for the GUS is tracker music which are largely found in the demoscene but the MPU-401 emulation thru MegaEm in DOS is decent.
You can use both sound cards at the same time if the motherboards have multiple ISA slots.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 3 of 4, by Shponglefan
I would put both the AWE64 and GUS PnP in the Pentium 233MMX system.
GUS is best suited for DOS games, especially those that use hardware mixing (e.g. certain Epic games). It's also highly useful for tracker music and demoscene stuff. AWE64 will give SB16 and AWE32 support which is ideal for DOS games from about 1993 onward.
For Windows 98 builds I prefer newer cards like those based on the Vortex 2 chipset for 3D sound support. SB Live! with EAX support would be another option to consider for Windows 98.
486 DX-33 with 5 sound cards
Tandy 1000 TL restoration
Ultimate Windows XP build
Reply 4 of 4, by dominusprog
Shponglefan wrote on 2023-11-21, 14:49:
That would be ideal.
