My GUS seems to have failed, lamentably
First post, by blakespot
Back in 1994 I purchased a Gravis Ultrasound, for obvious reasons.
The PC it was part of is long gone, but I could never (obviously) let the GUS go. In 2015 I rebuilt the PC I had it in and have enjoyed it since. I was upgrading the PC this weekend (CF boot card) and tied everything back together (case was closed, hours of using GUS happily -- so nothing happened that harmed it by my hand) and last night it stopped outputting sound. I verified it's not the amplified speakers at fault, and noticed when I turn the volume to max on the speakers, I can hear an ever-so-faint rendition of what is playing on the PC.
Is this something that likely can be fixed? This thing is worth its weight in gold and I can't really replace it because of my wife, so any advice is helpful.
So upset. Thanks.
bp
:: Visit the Byte Cellar, my vintage computer blog (since 2004).
:: See a panorama of my own Byte Cellar (a.k.a. basement computer room)...
:: twitter: @blakespot
Reply 1 of 33, by weedeewee
Which GUS exactly ?
Since you mention hearing a faint audio signal, I'm leaning towards either bad caps, bad voltage line (+12v) or bad output stage/amplifier on the GUS or failed voltage regulator on the GUS itself.
Do not ask Why !
Reply 2 of 33, by blakespot
And all of a sudden it's now working. After many many reboots -- 100%. Why??
Reply 3 of 33, by Shponglefan
Failing components can result in intermittent behaviors where sometimes things appear to work, but then they stop working.
Since you reported hearing faint sounds previously I'd wager there is something in the audio output circuit that might be failing (e.g. after the DAC).
It might be something as simple as corrosion on the audio jack.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 33, by weedeewee
Shponglefan wrote on 2023-12-28, 18:52:
Agreed,
or a cracked solder joint.
Do not ask Why !
Reply 5 of 33, by Tiido
Tht sounds like a mechanical issue indeed. My GUS has pretty bad output connectors, the plugs barely stay in and sometimes there's poor contact too. Perhaps yours is even worse and could use a connector replacement or at least a cleanup if possible.
Reply 6 of 33, by Joakim
My Gus needs an audio jack replacement as well. Any recommendations on parts? I can sacrifice one of those old OEM SB live cards I have lying around I guess. Seems like a fitting punishment. 😁
Reply 8 of 33, by dj_pirtu
If all the chips (GF1 etc.) on the GUS are socketed then pressing those down may help.
Reply 9 of 33, by florian3
Joakim wrote on 2023-12-28, 22:05:
I recently replaced the broken jacks of a GUS PnP with CUI Devices SJ1-3533NG.
Reply 10 of 33, by keenerb
My original GUS developed a bad headphone jack, exactly like you described. I ended up cutting of the end of a headphone extension cable and soldering the wires to the back of the card 😁
Reply 11 of 33, by blakespot
Shortly after my orig post, here, the card started outputting normally. Used it for hours just fine. The next day, today, it's back to where it was.
So, I pulled the GUS out and I don't see any bulging or leaking caps. The feel of the 1/8" jack is looser / wobblier a bit on the upper (output) jacks than the never-used input jacks. I get no normal output through either output jack attached to my Audioengine A5 speakers. I can hear FAINT audio when volume is at max on the speakers out of the Line-out (unamplified) jack, but I don't THINK that I can hear the same out of the top (amplified) output. I also see no heat flaring around the voltage regulators.
Bad caps would show some kind of sign likely, right? Bulge or leak? I'd like to fix this and am wondering what my best approach is likely to be. Thanks.
bp
Reply 12 of 33, by pan069
blakespot wrote on 2023-12-30, 20:06:
Maybe clean those edge connector (ISA) pads, the look very dirty. Maybe the card wasn't getting the required power at some point.
Reply 13 of 33, by weedeewee
Can you post a close up photo of the solderpads of both 317T regulators ?
By no heat flaring, do you mean no discoloration, like no slight browning around hot components ? which is good.
look for any ring like patterns in the solder, those can form due to thermal variations and resoldering those points, adding a little solder, fixes that, if any exist.
Do not ask Why !
Reply 14 of 33, by blakespot
pan069 wrote on 2023-12-30, 20:16:
That's mainly reflection angle of the light above -- it's scored but it looks quite clean, still - I did give the connectors a clean just now. Will try it out.
bp
Reply 15 of 33, by blakespot
Hold on --- what is RN2? I just noticed this...
bp
UPDATE: Looking back on build photos from 2014, I see that haze of whatever it is is there, just over RN2, so probably is not new. I can't confirm it was among the legs there, but the part on the red board was there back then (and it's been working fine until just the other day).
What I did to this PC recently that had me using it (it's been a while) is upgrading boot disk to CF card from mobo IDE controller and I did have to remove the GUS to get to the BIOS battery that was dead and I replaced. But, after putting it back together, GUS worked fine until the next day, so...
Reply 16 of 33, by blakespot
weedeewee wrote on 2023-12-30, 20:43:
Here's the shot.
bp
Reply 17 of 33, by pan069
blakespot wrote on 2023-12-31, 00:15:
Here's the shot.
bp
What's happening on the trace near R33?
Edit: Looking at my own card (same version as yours) it's a via but mine look like a properly tinned one (i.e. silvery in color).
Edit: What does the rear of your card look like? Can you post a photo?
Reply 18 of 33, by Tiido
It is worth reseating all the jumpers in 2x4 conf, they pass analog audio and are there for the 16bit play/record addon board that basically nobody has. JP4 and JP5 in particular as they carry GF1 output and total mix outputs. Other two are line and microphone inputs and not so improntant.
The card looks good on photos. The vias near R33 on one photo look like corroded through but on another they do look right, must have been a reflection issue during photo.
Reply 19 of 33, by Shponglefan
What sort of equipment do you have? Do you have a multimeter? Oscilloscope?
Generally my initial diagnostics approach would be:
1) Physical inspection for damage (corrosion, damaged components, broken solder joints)
2) Checking for shorts and continuity
3) Checking voltages and resistances
Since you mention being able to hear faint audio, that's a good sign that the sound generation portion of the card including the main chip is probably okay. My first area to focus on would be the analog portion of the audio circuit. I'd probably start with components like the voltage regulators, DAC, amplifier chips, caps, etc.
