First post, by BEEN_Nath_58
Before 2000s (mostly) - used to get any form of sound, unless you have a PC speaker of AC97 CPU emulation.
2000s - EAX, DS3D, A3D, etc in trend.
Post 2010 - ?
I am only aware of their uses in professional environment, but how will be gaming affected by modern sound cards?
Reply 1 of 30, by wbahnassi
LED lights 😋
Reply 2 of 30, by Oetker
I never buy top-end motherboards but in my experience the onboard sound can still be noisy with regards to 'computer noise' due to GPU load, scrolling, etc.
However to fix that I prefer a USB DAC. Recently I've been using a €10 Apple usb-c DAC for my headsphones and it sounds great and also acts as a mic-in. Great thing about using a USB DAC is that you don't need any (shitty) Creative, Realtek, whatever drivers.
So to summarize, no, I don't think there's a good reason to use a discrete sound card.
Reply 3 of 30, by Errius
"hearing the computer think"
Is this too much voodoo?
Reply 4 of 30, by Shponglefan
I've found both onboard sound and USB devices pick up internal computer noise. In my studio set up, I needed a USB isolator to eliminate the noise from my USB audio interface.
In contrast, Sound Blaster Z cards have been noise-free for me. For that reason alone, I use those sound cards in my modern rigs.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 5 of 30, by Dolenc
I use an usb sound blaster. External volume knob, works on many pcs(I use more), sound quality is better than what my best mb has, I can also use alchemy to get eax on older titles. My vortex2 plugs into its lineIn, so I can just keep headphones/speakers on the blaster.
Reply 6 of 30, by elszgensa
They serve to make things less convenient, since you now have another cable to deal with besides the HDMI/DP one. Well worth it, highly recommended! /s
Reply 7 of 30, by Shponglefan
elszgensa wrote on 2024-03-07, 16:15:
In my own setup, I'm using computer speakers. Whether I plug into onboard sound or a dedicated sound card, the number of cables is exactly the same. I would think headphones would also be the same number of cables.
Not really sure how there would be more cables with a dedicated sound card?
Reply 8 of 30, by cloverskull
Probably outside the scope of the original question here but I use a USB sound card with a KVM switch and now multiple computers can share it, which is pretty great IMO.
Reply 9 of 30, by keenmaster486
Only as a matter of convenience, and that mostly in audio interfaces like Behringer DACs that have XLR inputs so you can plug in a nice microphone. You're not going to gain anything that's actually useful in terms of audio quality.
World's foremost 486 enjoyer.
Reply 10 of 30, by Shponglefan
keenmaster486 wrote on 2024-03-07, 16:23:
As I mentioned earlier, my experience is that onboard sound and USB sound results in ground loops + system noise, whereas dedicated sound cards do not.
In that circumstance, audio quality is improved with a dedicated sound card.
Reply 11 of 30, by keenmaster486
Shponglefan wrote on 2024-03-07, 16:25:
That hasn't been my experience. I've been running a Behringer UMC404 for years now and have never had any ground loops or system noise. I have several UMC202s and never get ground loops or system noise with those either. This is across several desktop computers, laptops, and new motherboards. I also help run a small radio station, an application in which we have DAC -> ADC -> DAC inherent to our audio chain, making a clean, noise-free output and input crucial, and after getting terrible results with brand new PCIe Sound Blasters and pulling our hair out, we switched to Behringers and never looked back. They've been working perfectly with no ground loop or other issues for almost 10 years now, with no noticeable degredation in audio quality despite two D/A conversions in the chain.
Reply 12 of 30, by Shagittarius
Am I the only one who cant get onboard sound devices to encode surround sound properly? I use a sound card so I can get 5.1 surround in all titles on an optical out.
I'm asking this in seriousness , I've tried on 2 motherboards and something doesn't work.
Reply 13 of 30, by konc
Shponglefan wrote on 2024-03-07, 14:48:
Ground loop issues are indeed common with many USB DACs. Not all of course and my limited experience shows that it's an unfortunate combination of DAC+computer, the same DAC may not have the same issues on another computer.
Reply 14 of 30, by Shponglefan
keenmaster486 wrote on 2024-03-07, 16:32:
You're fortunate if you've never had to deal with ground loop issues. I've found them to be constant headache in my own home in conjunction computer audio.
My own studio setup has be plagued by these issues. Doesn't matter which hardware, connection types (USB, FireWire, Thunderbolt), or motherboards, the problems remained.
I went through a whole bunch of mitigation strategies including BIOS tweaks to reduce system noise, but could never eliminate it. I finally solved it with an Intona USB isolator. It was a somewhat pricey option, but worth it to get clean audio output.
Reply 15 of 30, by Shponglefan
konc wrote on 2024-03-07, 16:39:
I've generally had more issues than not with USB devices and audio noise. Even using laptops at different physical locations (e.g. different power grids).
It is a major PITA to deal with.
Reply 16 of 30, by midicollector
I've heard they still have better sound quality, but I don't know if that's true or not. Haven't used a modern sound card since the audigy. I would be curious to try one though, I might have to pick one up one day.
Reply 17 of 30, by Macharper
I use a Creative X-Fi Plat Fatality *PCIE* which was the last boards to feature Hardware EAX. Still functions under Win11 (using Alchemy) for older games. I recently upgraded my mb so it was essential to get one with an older slot. MSI MAG Z790 did.
I find the output fantastic for modern gaming too, I tried the Sandblaster G6 for a week, but returned it, I preferred my older card for clarity and richness when driving my headphones,.
Reply 18 of 30, by wierd_w
The issue with "Noise" is basically eliminated on modern HDMI based audio solutions, since it is all digital.
Discrete cards that have SPDIF/Optical output should likewise have no issues. Some motherboards have this port as well.
System-hum-noise is an artifact of all-analog audio solutions. On-board devices from the 90s and early 2000s are almost always all analog, and are particularly nasty about having the hum and other noise. I insisted on getting a crystal labs card for builds during that era for that issue, along with the "Drags the computer to a grinding halt!" issues with some SoundMax based AC'97 audio solutions from that era.
On anything modern(tm), which has digital audio outputs, the need for a discrete card is basically zero.
Reply 19 of 30, by konc
wierd_w wrote on 2024-03-09, 06:08:
As long as you have something with a digital input 😉
