Reply 420 of 424, by Snoozer
Wouter wrote on 2023-03-10, 02:41:I had this same problem on a Pentium MMX 233 with an Aztech 2320 based card. I checked the MIDI IN pin with an oscilloscope, and it had full amplitude high frequency noise on it. My hypothesis was that the level converter on the WP32 could not handle the high capacitance on the MIDI IN line of the sound card, so I added an AC terminator (series capacitor and resistor) between MIDI IN and GND. Now it works perfectly.
I'm having a similar problem with an Aztech 2316 based card. It would be appreciated if you could provide a little more detail regarding the AC terminator modification. What value capacitor and resistor did you use? Did you solder these to the sound card at the back of the wavetable header, or on the McCake itself?
