Reply 300 of 315, by mockingbird
Kordanor wrote on 2024-04-15, 16:29:Yeah, thats what I tested. I do get the music, but I dont get the sound (neither the thud, nor the death sound).
I tested it with a Soundblaster Live (emulated as SB16 in DOS). With that card it works. But with my ESS1868 I only get the music. And a totally broken soundeffect on some driver files (which are so loud and broken you immediately want to restart the PC). Can you attach the drv file which you use? Thats likely also different just by using a different version of the game.
Are the drivers (outside of the file) relevant? I tested it with ESS Drivers as well with unisound though, and it doesnt seem to make a difference.
It's in the "SBPRO" directory from the aforementioned thread you linked to (ct-voice_all.7z). The version I downloaded initially had a 'ct-voice.drv' from 1996, and that didn't work (maybe for SB16?). Are you initializing ESSCFG.EXE? Do you have the SET BLASTER paramater defined? Definitely try ESSCFG instead of Unisound.
