Reply 861 of 991, by polpo
scroeffie wrote on 2024-05-14, 14:41:
any resellers in europe ?
I'm happy to announce that Serdaco will be selling the PicoGUS in Europe soon at https://www.serdashop.com/ !
dely wrote on 2024-05-17, 18:21:
I try to download Ultrasound installation files from github page and I am redirected to https://picog.us/. Is it possible to download this archive from somewhere else?
I fixed the redirect and the link should now work. Sorry about that. I'm starting to move the project page over to that domain.
Reply 862 of 991, by rolierop
[quote=I noticed the compatibility list on the GitHub appears to be out of date, specifically with regard to the IOCHRDY bug on 5150/5170 (and ostensibly 5155/5160/etc as well) that was supposedly fixed with firmware 1.0.2. I have a 5160 I plan to test mine on and submit a compatibility update for if it goes well.
[/quote]
Is the PicoGus already working ok with a Sis chipset (486)?
LuckyStar 486E C2 | Intel 486DX4 100 WB | PicoGus
MSI MS-5168 | Intel Pentium 233 MMX | Sound Blaster Live
Asus P2B-F|Intel Pentium III 550 | Yamaha Audician 32 + Dreamblaster
MSI P35 Platinum | Intel Core2Duo E8600 | Sound Blaster Audigy 2 Value
Reply 863 of 991, by digistorm
rolierop wrote on 2024-05-18, 15:38:
It at least works with the SiS 85C407 / 85C471 chipset on a Soyo SY-025 K motherboard.
Reply 864 of 991, by Shponglefan
Couple questions about the PicoGUS.
Based on my understanding of the wiki, each sound card emulation requires different firmware.
How practical is it to use it to emulate multiple sound cards in one system? I am assuming this would involve re-writing the firmware each time to switch between different emulations.
Will it be possible to have a single firmware and some sort of software controls to switch between emulations or is that not practical with the hardware?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 865 of 991, by Shreddoc
Shponglefan wrote on 2024-05-20, 03:50:
It is quite practical. The firmware rewriting can be done at the DOS prompt, and takes only a few seconds. So, for example, you can easily incorporate the firmware changes into DOS batch files.
This two minute section of Phil's Youtube video at https://www.youtube.com/watch?v=oEHVB0FITqU&t=256s shows this in action.
This approach is a development-in-progress, and is discussed at this Github issue :
https://github.com/polpo/picogus/issues/39
Reply 866 of 991, by Shponglefan
Shreddoc wrote on 2024-05-20, 04:19:
It is quite practical. The firmware rewriting can be done at the DOS prompt, and takes only a few seconds. So, for example, you […]
Thank you, that's great info!
Reply 867 of 991, by polpo
The next firmware release will enable MPU-401 simultaneous with the other modes. Note that this means that any modes that use an IRQ like GUS or SB won't be able to use MPU interrupts, i.e. anything with a "1" on this list will have to use MPU-only mode: https://github.com/bjt42/softmpu/wiki/Compati … gent-Mode-Games.
Reply 870 of 991, by rolierop
digistorm wrote on 2024-05-18, 15:46:
Cool, I will test it on a LuckyStar Ls486E with SiS 85C496/497 soon.
Reply 871 of 991, by snipe3687
Does anyone have the design files for the I/O bracket? I really enjoy building my own cards which I'm in the process of, but I don't necessarily want to do a 3D printed bracket. I will if I have to though. Problem is, I don't see the files anywhere for the one that is being sold with the PicoGus which is obviously preferable.
Reply 872 of 991, by appiah4
snipe3687 wrote on 2024-05-21, 12:11:
The v2.0 bracket STL is basically on the github:
https://github.com/polpo/picogus/blob/main/hw … d%20bracket.stl
The V1.x bracket can be found here:
https://www.printables.com/model/303031-picog … undcard-bracket
I believe @polpo had linked to this in a twitter post.
Reply 873 of 991, by snipe3687
appiah4 wrote on 2024-05-21, 12:37:
The v2.0 bracket STL is basically on the github: […]
Ok apparently, I'm blind. thank you!
Reply 874 of 991, by digger
Okay, first of all, I'm not the first to come up with the following idea. LSS10999 floated it earlier before in the dISAppointment thread, and nukeykt, who responded in that same thread, has actually developed a proof-of-concept LPC-Sound-Blaster, albeit based on an FPGA, instead of something like the Pico.
I just watched this video by someone who managed to wire a Raspberry Pi Pico up to the LPC bus of a more modern motherboard in order to use the Pico as a BIOS POST card.
So apparently the GPIO pins of the RP2040 can be interfaced with the LPC bus as well.
For those who don't know: ISA still more or less exists in modern motherboards in the form of the Low Pin Count (LPC) bus. At the software level, LPC is compatible with ISA.
Also, many of you are probably familiar with the dISAppointment project, that aims to develop an LPC-to-ISA adapter.
Of course, the primary use case for such an adapter would be the use of ISA sound cards in more modern post-ISA motherboards.
But if the RP2040 is fast enough to emulate all these old DOS-era sound cards we love, and it also can directly interface with the LPC bus, then wouldn't an LPC variant of the PicoGUS be a cool project as well? And perhaps also more convenient?
Yes, I know, the LPC bus has a few known caveats:
  • There is no standard connector or pinout for LPC. Usually it has to be tapped into through solder pads or possibly a TPM header, but even those have differing pinouts between motherboards.
  • DMA support is optional in the LPC spec, and since TPM modules don't typically require DMA, it's often not available even in motherboards that have a TPM header.
But the GUS supports programming modes that don't require DMA. Also AdLib, MPU-401, Tandy and CMS all don't need DMA at all. Nor would the Disney Sound Source, if emulation support for that sound device could be added as well (including an emulated printer port through which it would be accessible, just like an actual DSS). Ditto with Covox Speech Thing emulation.
As for the "non-standard pinout" problem, I would assume that the dISAppointment project is working out solutions for that problem as well. Perhaps by making some adapter (ribbon) cables available for the most common variants found in the wild?
Something like a "PicoGUS for LPC" would suddenly open up native DOS sound support in a lot more modern systems as well.
I know, with the development of quality ISA sound card emulators such as SBEMU and VSBHDA, there are now alternatives available, but there's just something about having a (quasi)hardware solution as well. And it would put the (otherwise mostly often unused) TPM headers to good use as well. 🙂
I'm particularly curious about what you think about this, @polpo. Have you considered something like this? There's a good chance that this has crossed your mind before.
And would this idea perhaps be worth spinning off into a separate topic, so other people with the necessary skills could join in as well?
Reply 875 of 991, by rasz_pl
digger wrote on 2024-05-21, 20:53:
I posted about this 3 months ago Re: dISAppointment - LPC to ISA adapter - ISA on modern motherboards and a year ago Re: dISAppointment - LPC to ISA adapter - ISA on modern motherboards 😀
$5 LPC sniffer using Pico https://github.com/stacksmashing/pico-tpmsniffer
Reply 876 of 991, by bfarmilo
With the recent release of the Pocket 386 on Aliexpress is there any intention to do another run of the PicoGUS Femto edition? This would be a great option for digital sound on these little devices.
Reply 877 of 991, by tobiasrieper
I am interested in one of these cards, would these be better than my current ESS1868 cards? I currently use that and an ewave. I love playing Duke 3d, Doom and Raptor.
Reply 878 of 991, by polpo
bfarmilo wrote on 2024-05-23, 10:18:
Yes, I have 50 Femto boards that arrived from JLCPCB this week. This weekend I will assemble them and put them on my Tindie store. If you sign up for the waitlist you can be notified when I restock. https://www.tindie.com/products/polpo/picogus … and386-and-isa/
tobiasrieper wrote on 2024-05-23, 16:05:
PicoGUS should work great with all of those games and the MIDI soundtrack will be better in the GUS mode (some people do like the FM versions better, though...).
