Reply 40 of 420, by carlostex
Just opened my MU80, and battery is soldered definitely soldered or fixed in some other way i can't understand. Anyway, it's not a regular CR2032. At least mine is very clean and not leaky.
Reply 42 of 420, by Robin4
Is this problem also with MT-32 and CM-32L?
I have to check mine soon as possible.
Reply 43 of 420, by dank0
Thanks for this info I just opened my SC-55 and the battery was slowly leaking.
Robin4: MT-32 doesn't have any battery inside. I did open the box to make sure that I don't have same situation like with SC-55.
now i'm going to check the MU-80 😉
AMD K6-II 500, Nvidia TNT2 AGP, 256 MB RAM
•• WANTED: ROLAND SCP-55 ••
Reply 44 of 420, by Malik
About the CR-2032 batteries - you can also get them at camera selling shops too.
Reply 45 of 420, by sliderider
There are Chinese sellers who have them in bulk packs on ebay for only pennies per battery. A 100 pack would probably be a good investment for almost anyone who has a lot of old hardware lying around that needs at least one of these.
Reply 47 of 420, by Mau1wurf1977
I got two packs of four Energizer branded ones.
Quite pricey relatively speaking, but what can you do 😀
Will swap the batteries later today although none have been leaking.
My YouTube channel
Reply 48 of 420, by Robin4
which midi modules have batteries?
i have a roland CM-300 and a roland CM-32L
Reply 50 of 420, by emgillis
I removed the battery from my SC-55mkii a long time ago -- because I put the box into cold storage.
I took it out of storage, and found out the manual doesn't list the internal battery model, only the remote.
Is the SC-55mkii a CR2032, or something else?
THANKS!!!
Also... I just joined this site. I have to say, as a colour blind person, the question to verify the colour of the background or foreground REALLY blows
Reply 51 of 420, by emgillis
Second questions... is it positive side up? I haven't opened the box yet, so i don't know if it lists the battery type or the polarity on the board.
Reply 53 of 420, by Malik
Yes, it's a CR2032 battery. I just changed mine (MKII).
Reply 54 of 420, by emgillis
awesome! Thanks!!
Reply 56 of 420, by badmojo
Nice save! These button batteries seem to die more gracefully than the old barrel things, which spew acid far and wide. Still not a good look though.
What do you guys do with old batteries? I've been vaguely aware that they shouldn't be thrown into the bin, but that's exactly where I've put them all my life. I've done a bit of research and discovered that there are numerous places near where I live which accept dead batteries to be recycled, who knew?
Reply 57 of 420, by Stretch
How do I remove the battery from the SC-55 MKII?
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Sound BlasterX G5
Reply 58 of 420, by PeterLI
You may need to use a gripping tool in case your fingers cannot grip it sufficiently. 😀
Reply 59 of 420, by Logistics
I've always hoped to acquire one of these and do a polymer recap plus bipolars and films for audio. Someday...
