Okay, i found the file i was referring to before.
This is how the Doom intro should sound on a SC-55, notice the whispy, sweepy effect on the halo pads is very distinct and defined, and becomes a deliberate part of the tune.
https://www.youtube.com/watch?v=tykAn_7aRP4
Here is the doom intro recorded on a real SC 8850 (from this site - though the "play midi files for you" function doesn't appear to work any more for those interested):
I can't remember which is the sc-55 map and which is the 8850 map but they both sound very similar to me - i'm guessing the 8850 (and 8820) use the same halo pad patch in both maps?
And here is is on the SC VA with the SC 55 map:
And here are only the halo pads:
To me, these seem reasonably similar and the halo pad whispy, sweepy noise is way less pronounced and distinct than on a SC-55
Not sure how the 8850 compares to the 8820 that the SC VA vsti is trying to emulate.
According to wikipedia:
Roland ED SC-8850 1999 GM GS GM2 64 128 1640 63 24-bit @ 32kHz Desktop module that can connect via USB. Contains a new native map as well as SC-55, SC-88, and SC-88Pro maps for backwards compatibility, however compatibility with MIDI files made for these modules is poor
Roland ED SC-8820 1999 GM GS GM2 32 64 1608 63 24-bit @ 32kHz Mobile MIDI device with no display, successor of the SC-88ST Pro. USB-powered, but does not act as a full USB audio device. GS Advanced Editor or another program is highly recommended when using this synth. Despite similarities, patches and effects occasionally play differently from the 8850 - some samples on the 8850 are stereo while the 8820 versions are mono and vice versa.
Anyway, that's just a small example, see what you think.
