Reply 40 of 53, by brostenen
PhilsComputerLab wrote:
brostenen wrote:
Phil:
Was those scripts in the link to the midi-diy that I mentioned, at any use?
Hmm I don't see how these are related to be honest...
I was just thinking, that you might be interrested in how to add a shutdown button for standalone midi module without any monitor. 😀
Reply 41 of 53, by PhilsComputerLab
Oh, I thought you were talking about compiling Munt.
YouTube, Facebook, Website
Reply 42 of 53, by brostenen
Nono.... 😁 😁 (sorry that I was not that specific)
I was just referring to the post I made on the first page of this tread.
I saw that you started with fluidsynth, and I remembered that the PiMidi on Instructables,
were based on Fluidsynth. And I remembered that it had a shutdown/reset thing going on.
Reply 43 of 53, by PhilsComputerLab
Ah, no worries, I get it now 😀
Reply 44 of 53, by BloodyCactus
Personally, Id just target pi3, it has the best performance. adding stuff to target the much slower pi1/pi2 is pointless imo.
Reply 45 of 53, by PhilsComputerLab
I'd be happy with that 😀
Reply 46 of 53, by brostenen
Would the idea of a small TFT screen on the PI, add something useable?
Reply 47 of 53, by PhilsComputerLab
Yes, I was hoping others go nuts with stuff like this 😀
Reply 48 of 53, by brostenen
Sweet.... So... Basically, one could build a standalone synth, with Munt or Fluidsynth UI loaded upon boot and have it touchscreen controlled.
Reply 49 of 53, by hard1k
And even add a cool sound card (originally by Wolfson) 😀
https://www.element14.com/community/community … ogic_audio_card
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 50 of 53, by brostenen
Perhaps a tone regulator module from eBay too... To add treble and bass controll ?
And perhaps add real 5-Pin DIN midi plugs as well. (MIDI in/through/out)
PI + Wolfson + TFT + Tone regulator + 5-Pin DIN.... 😜
And if it is capeable to load SF2 banks, then there must be a ton of use for this device.
Reply 51 of 53, by gdjacobs
Until Raspbian gets a 64 bit version, Pi 2 and Pi 3 are kind of the same thing from a software perspective.
Reply 52 of 53, by BloodyCactus
Yeah. Im only aware of the arm8-a (pi3) having CRC instrutions that clang enables by default thats not in pi2's arm7-a core, but otherwise a pi3 arm8 binary should be able to run on a pi2 ok. and of course a pi2 binary would run fine on a pi3, just not be as well optimised.
When i switched my pinball controller out from a pi2 to pi3 the performance difference was huge (but I am using threading and such), Id rather target pi3 over 2 than deal with stuff like people complaining about choppyness or dropped midi frames or whatever.
Reply 53 of 53, by gdjacobs
As far as I'm aware, the convention so far has been to build a ARMv7 binaries and use them for both the Pi 2 and 3. The foundation doesn't seem in much of a hurry to move to ARMv8.
