Simmconn AWE64 Adapter
Reply 100 of 550, by cyclone3d
I'll try to find an old program that can read the files properly.
Since the older chips are not available anymore, some rework would definitely have to be redone, but that shouldn't be too much of an issue.
I am not volunteering to do anything other than try to find a program that can open the current files.
I may actually have an old program that can do it, but I'll have to check. It has been a few years since I even looked into circuit board design and may no longer have the programs.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 101 of 550, by dexvx
kithylin wrote:
dexvx wrote:
I'm interested as well. Someone should start a kickstarter!
The problem is that while there are interested parties.. some folks here said they're looking in to it and it may not be technically possible to re-create today. At least so far.
From reading this thread, I thought the component in question (PALCE16V8H7JC), is no longer produced. However, there is still some stock left in lesser known distributors. Since individually ordering them may create scaling issues, making a KickStarter to finance the adapter beforehand would seem like a good solution to at least get some volume. Of course it would take a hardware engineer to do it, and although the Simmconn guy says it cannot be commercial, I think part of the cost of subsidizing the person's time is not unreasonable.
Reply 102 of 550, by cyclone3d
If I were remaking them, I would much rather use the newest substitute part. Sure it would take a bit of board reworking, but if the inputs/outputs are the same then it is a simple task of rerouting the traces to where they need to be for the new chip.
YMF7x4 Guide
Reply 103 of 550, by cyclone3d
The .PCB and .SCH files can be opened and updated to the new format in Altium Designer.
I have already converted the files and am working on putting them in their free CircuitMaker application.
YMF7x4 Guide
Reply 104 of 550, by cyclone3d
I have converted the PCB files via Altium Designer 17.0 and then saved them as Altium PCB 5.0 files and imported them to CircuitMaker (Altium's free PCB design suite which is meant for open designs and saves to the cloud).
The Schematic was also converted and then saved as a newer DXF file and added to the project. I have also attached all the original files as well as the Altium Designer 17 files to the project.
You can sign up/download/access the project by going here:
https://workspace.circuitmaker.com/Account/Login
The project name is:
SIMMCONN_GOLD
YMF7x4 Guide
Reply 105 of 550, by kithylin
cyclone3d wrote:
I have converted the PCB files via Altium Designer 17.0 and then saved them as Altium PCB 5.0 files and imported them to Circuit […]
SIMMCONN_GOLD
Awesome. Thanks for doing this for us.. so we're 1 step closer to this thing becoming a reality.
Reply 106 of 550, by cyclone3d
You're welcome!
If somebody can get me the newer part numbers and data sheet for the GAL ? that is no longer produced, I can see if I can maybe rework the board design to fit the new chip. It just depends on how different it is.
I did a search for the original part and came up with this:
http://www.findchips.com/search/palce16v8h7jc
Not sure how those part numbers correspond compatibility wise to the part number posted up above.
I also downloaded the data sheet (I think) and attached it.
YMF7x4 Guide
Reply 108 of 550, by SIMMConn
cyclone3d wrote:
You're welcome! […]
You're welcome!
The Atmel (now Microchip) ATF16V8B/BQ/BQL should be drop-in replacements for the GAL. I remember -15 is the minimum speed requirement, but I would use -10 to be safe. You would need a device programmer to program it before assembly, or you could use a socket.
The most difficult part for me to get was the dual-row 2.0mm pitch receptacles. I had to had them custom ordered from Taiwan back then. Now there are a few varieties you can get from Digikey. The 72 pin SIMM sockets are also available but are quite expensive. A trip to the local electronic surplus store should get you most of the parts for not much money.
If you have a chance to modify the layout, you could add 33 ohm series resistors on the output of the 74AC(T) buffers to improve the signal integrity. Those are nasty drivers.
Thank you for your effort keeping the project alive and serving the community. Please feel free to do a group buy or something like that.
Reply 109 of 550, by cyclone3d
SIMMConn wrote:
The Atmel (now Microchip) ATF16V8B/BQ/BQL should be drop-in replacements for the GAL. I remember -15 is the minimum speed requir […]
cyclone3d wrote:
You're welcome! […]
You're welcome!
Thanks for the additional information! I'm not planning on actually building these myself... at least not at this time. I was just trying to help by converting the files to something that is usable with newer software.
YMF7x4 Guide
Reply 110 of 550, by matze79
still progress here ?
Reply 111 of 550, by kithylin
Nope. No progress, no one's taking up re-making these yet.
Reply 113 of 550, by 386_junkie
Hi cyclone,
Trying to get me head around this and educate myself with what has been done on this to date.
Do you happen to know the part numbers of the 3 original IC's? I take it not all of them can be sourced?
Reply 114 of 550, by appiah4
If this gets a new profuction run or turns into a new prosuct I will buy at least two. Poşnt me to the kickstarter.
Reply 115 of 550, by kithylin
I would as well. As long as they're somewhat affordable.. not like $150+ each.
Reply 116 of 550, by hard1k
I guess if a new product is to be designed, one should expect the secured demand for >100 boards (judjing from the actual sales record for my naked GUS PnP RAM Adapter PCBs that were far less complex and had a veeeeery much more limited potential users' community).
In order to make the product better than the original (and cheaper as well) I'd suggest avoiding any RAM sockets (as both the sockets themselves and the RAM modules are relatively expensive) by putting the maximum amount of RAM on board (I guess, for instance, four 64MBit chips would do just great). Thus the overall PCB surface would be less, no sockets needed, and no annoying outstanding parts that could interfere with other neighboring expansion cards.
If such "advance" CT1950 is to be designed and produced, I'd be after 2-3 of such if it still stays withing some reasonable limit, say $50/each.
Fortex, the A3D & XG/OPL3 accelerator (Vortex 2 + YMF744 combo sound card)
AWE64 Legacy
Reply 117 of 550, by xjas
I'd be down for one if it had 32MB soldered directly onboard. I have two of the originals but once they're fitted with a SIMM they're WAY bulky. A 'slimline' model would be really appealing.
Reply 118 of 550, by kithylin
The hard limit on these is 32MB so just a single 32MB memory module surface mounted on it instead of the socket would be enough / all it needs. Even then the cards themselves only address 28MB of it.
