TNDLPT : Tandy Sound on parallel port
Reply 60 of 187, by jaZz_KCS
What does that mean specifically in terms of compatibility regarding EMM386? Is standard Tandy not supported at all with EMM?
Reply 61 of 187, by matze79
pdw wrote:
It's not possible to intercept the standard Tandy audio port 0C0h with EMM386. With EMM386 the TSR intercepts ports 01E0h (later Tandys), 0205h (IBM PS/1 sound card) and 02C0h (the Lo-Tech card).
What Games support 01E0h ?
i don't know any.
Could the TSR be made to also support forwarding 0C0H to 2C0h to support the Tandy Soundcard ?
i also think i can send you a card when its ready 😀
this might come handy, due to the card can not listen on 0C0H on 286+.
Does JEMMX work with 0C0H ?
Reply 62 of 187, by pdw
Standard Tandy won't work with EMM386. You'll need to patch the games or switch to QEMM.
I don't know. I haven't started on a JEMM version of the driver yet. JEMM's documentation is very fragmentary, there's no way to know without testing.
What Games support 01E0h ? i don't know any.
Some Sierra games have a driver for these "new Tandys". But that driver has machine checks and it also looks like it tries to use the Tandy DAC, so it won't work. I don't know of any other games.
Sure. That's easy.
Reply 63 of 187, by jaZz_KCS
So I take it as there will be a TSR package available in the veins of the adlipt package, with a patcher and a TSR?
Reply 64 of 187, by carlostex
Is this your experience or are you just making an assumption?
Reply 65 of 187, by dreamblaster
Yeah, a TSR is already under test and seems to work.
No patcher yet, but it can be done (especially for sierra games).
Thanks for your support !
Reply 66 of 187, by Scali
Hum, for the lo-tech Tandy Clone sound card, I modified TEMU to redirect C0h to 1E0h or other ports, and that seemed to work fine. I believe it sets up its own v86 environment. It should be easy to replace my redirection code with code for TNDLPT, then we'll have a TSR without this problem.
Reply 67 of 187, by matze79
yeah but temu has plenty of incombatiblities.
Does not work on:
Sanyo 386 Laptop - 386SX20
Escom Blackmate - 386SX33
it loads the tsr, and after 1 or 2 seconds system looks up at command prompt.
Yeah resource conflict.
it may work on a 286XT but not on a AT Machine.
My K6 will only boot with 2C0 set on the Card.
Reply 68 of 187, by bjwil1991
CuteMouse 2.0 Alpha 4 does the same thing to me on my Packard Bell Pack-Mate 28 Plus, but version 1.9.1 and 2.1 Beta 4 works.
Reply 70 of 187, by dreamblaster
new prototype
The attachment tndlpt.jpg is no longer available
Reply 72 of 187, by Super_Relay
I 100% love the volume wheel. it feels so period correct.
is it the same as the ones they advertise for repairing gameboys?
Reply 73 of 187, by Solarstorm
A bit off-topic, just out of curiosity.
What kind of EDA do you use?
My YouTube Channel
Reply 74 of 187, by carlostex
It works on my 286 and on my 386. Granted i have no hardware inside that makes use of High DMA. The only downside is increased noises coming from the card, compared when using the card on an XT.
Reply 75 of 187, by dreamblaster
Kicad
Reply 76 of 187, by matze79
Did few tests, it also works on my 486 ISA, but not on K6 and Pentium, also does not work on my 486 PCI System.
@dreamblaster
Nice,i like the pot on the TNDLPT =)
Reply 77 of 187, by matze79
Did you choose Resistors and Capacitors for the Input Stage of the Amplifier to match the original Tandy ?
Somewhere i saw the schematic of the Tandy Amplifier Board. 😀
EDIT:
Found it.ftp://ftp.mindcandydvd.com/pub/drivers/Tandy/ … ence_Manual.pdf
Site 81 shows the Amplifier.
Lo-tech uses 470nf for Output Capacitor, you use 47uf.
And here is the Tandy 1000EX:
The attachment tandy_Amp.png is no longer available
Reply 78 of 187, by Solarstorm
dreamblaster wrote:
Kicad
Yay for Open Source!
My YouTube Channel
Reply 79 of 187, by digger
dr.zeissler wrote:
the next BIG stuff should be an all in one device: - Covox (stereo) - OLP2LPT - OPL3LPT - DSS - TSS and switchable per software […]
- Covox (stereo)
- OLP2LPT
- OPL3LPT
- DSS
- TSS
and switchable per software so you can "configure" the device in a batch before starting the game 😀
In addition, it would be really nice if some of these modes could be combined and used at the same time. So one music device (TSS/OPL2/OPL3) together with one DAC device (Covox/Stereo-on-one/DSS), all on a single parallel port. This would allow machines lacking both available ISA slots and built-in Sound Blaster compatibility (such as older laptops, Microchannel PS/2 systems and later PCI/PCIe-only computers) to support both music and digital audio in many games, even if they would require some software emulation and/or patches to make it work with most existing DOS games. I recently started a separate topic for that: Multiplexing multiple sound devices on a single parallel port? (OPL2LPT, DSS, etc)
