Update SC-55 ROM
First post, by tpowell.ca
Hi guys,
So I've been reading up on the incredible variations of SC-55 ROM versions of the mk1 generation.
It would seem that for the most complete DOS compatibility of Sierra/Dynamix/Lucas games from the early to mid 90s era, the Control ROM version to go for is 1.21.
<1.20 supports Capital Tone Fallback but not General Midi instruments.
1.20 / 1.21 supports both Capital Tone Fallback and General Midi instruments.
2.00+ loses support for Capital Tone Fallback but retains General Midi instruments.
Does this sound correct?
Do we know what other changes there have been between ROMs 1.20 and 1.21? What else did ROM 2.00 bring?
Cloudschatze has stated that cross-compatibility is limited to the following:
CPU ROM v1.00 is only compatible with a v1.0x control ROM (only 1.00 exists)
CPU ROM v1.10 is only compatible with a v1.1x control ROM (only 1.10 exists)
CPU ROM v1.20 is only compatible with a v1.2x control ROM
CPU ROM v2.00 is only compatible with a v2.0x control ROM
It just so happens that I have a 1.20 Control ROM version unit, but how do I upgrade it?
The removable chip is identified as a ROLAND part, and the one I want is R15209363 (1.21).
Is this replaceable by a simple EEPROM chip? If so, which one is compatible?
Thank you
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 1 of 24, by keropi
IIRC you need a 256kbytes rom so a 27C020 and variants will work fine
edit: yep 27C020 is the correct part - I used in the past some 27SF020 eeproms
look at the rom pic here: https://modelrail.otenko.com/retro/roland-sound-canvas-sc-55
Reply 2 of 24, by CrossBow777
So you can dump and burn eproms then? I've a request over in the MT-200 thread where the the OP would like to get a hold of newer firmware for his MT-200 since both of the units I own have a version 2.0 and 2.01 firmware on them and his is apparently version 1.0.
I don't have an eprom programmer to do it myself but....
Midi Modules: MT-32 (OLD), MT-200, MT-300, MT-90S, MT-90U, SD-20
Reply 4 of 24, by Cloudschatze
The v2.00 SC-55s do support capital tone fallback. There is a slight difference in drum set Program Change behavior however, affecting the improperly-programmed sequences of at least two known game titles.
Apparently not all GS-only sc-55s are the same, some are GM
One of the bugs present in 1.20, and fixed in 1.21, relates to the processing of multiple, consecutive NRPN messages. This is only an issue where the playback of particular GS sequences is concerned. I can provide a recorded example demonstrating this bug, if there's any interest.
Reply 5 of 24, by ssdj
Hi, I recently just aquired a SC-55 1.20. How much does the bug effect on the DOS games? Would that be a problem on most games?
Should I be worry about it and look for a 1.21 instead?
Reply 6 of 24, by Slot1
I also got GS-only SC-55 with 1.20 ROM recently. I've found 27C020 for $1 shipped. Whats the cheapest programmer that I can use? I see some available on Aliexpress but i'm unsure which one to get. Also where can I find the 1.21 dump ROM file? Thanks!
Reply 7 of 24, by derSammler
No, since the bug is GS-related. In GM mode, this bug will never occur.
Reply 9 of 24, by Slot1
Thanks keropi, but I think TL866 is expensive for just one job. It is the same price I paid for the SC-55. 😁
What about those 3 or 4 dollar ones, like SP200S?
Reply 11 of 24, by Slot1
Greece's Neighboring country 😀
Reply 13 of 24, by Slot1
Wow, thank you very much, you are the best. 😀
Reply 14 of 24, by Slot1
I received the 1.21 ROM chip!
Removed the Toshiba battery, not really needed. Thankfully the board was not damaged from the battery leak.
Installed the new chip.
Works great! Thanks keropi!
Reply 16 of 24, by Dusko
Hello all,
I finally got a SC-55, the ROM is 1.10 (Firmware), the Roland chip is R15199775, is this one the control ROM?
According to this thread I can't upgrade the ROM firmware to v1.21 or 2.0?. The Roland chip is not on a socket and it will be a pain to remove it, not to mention finding the right one in the wild, I have no plans on doing that.
I have a programmer to upgrade the rom, but I guess I should NOT be using 1.2x or 2.x firmwares?, If so, how bad is version 1.10?? any concrete comparisons between mine and 1.2 and 2.0?
https://www.youtube.com/@myoldpc9458
Reply 17 of 24, by Oetker
Dusko wrote on 2020-09-05, 06:04:
Hello all, […]
Hello all,
Here's what I have pieced together:
Early SC-55's have an incorrect instrument mapping, #122 is 'Key Click' instead of 'Breath Noise'. Some Duke3D tracks use Breath Noise. This is an issue on units with firmware < 1.20. Which is at least all units that say 'GS Standard' instead of just 'GS' or 'GS/GM', but also some 'GS' units. Unfortunately it seems Descent wants the incorrect mapping.
Firmware 1.20/1.21 have the correct instrument mapping, and they run a GS reset instead of a GM reset (i.e. GM reset doesn't turn off GS features). Newer devices disable GS features on a GM reset, which can mess up some (Build Engine) games.
Firmware 2.0x and SC-55Mk2 units fix the reset issue. It seems GS/GM units always have 2.0x firmware, and some GS units do.
Mk2 units lose 'Capital Tone Fallback', which means an instrument's capital tone is used instead of a variation if that variation doesn't exist. Again, some games depend on this behavior.
Firmware 2.0x and Mk2 units play silence where some drums have a duplicate program change number on the earlier versions.
So for some games, your firmware version will result in incorrect behavior.
Reply 18 of 24, by Dusko
Hi Oetker, Thanks for your comments, I have a better picture now, I was so exited about this unit because it looks so brand new, doesn't have a scratch, it came with its original box! I'm still happy about it but with mixed feelings. The good thing is that I also own a mk2 so that'll cover for those games. Not exactly sure how accurate the sounds will be from the mk2 compared to an original SC-55 (assuming both have same midi "formats"). For example, I have a SC-88 Pro and while playing Shadowcaster noticed that the levels on some instruments are lower in the mix and it just didn't feel right, I needed to put some instrument levels up to get it right. Yes, I know I can just use the button for SC-55 mapping mode which did the trick, but I don't remember where I read that the SC-88 Pro in SC-55 mode is still not as exact as an original SC-55, don't know if this is true or not.
If the mk2 accurately covers the gap I have, I guess I'm good to go!
Again, I'm not supposed to use a firmware above 1.1x, correct? does anyone know this for a fact? Is there a version I can upgrade to between 1.10 - 1.19?
Reply 19 of 24, by keropi
I'd say just enjoy the SC-55 it's a great unit
I actually prefer the old GS-only ones and it's the unit I power up in games even though I have a mk2
don't let small insignificant differences spoil your gaming 😉
