First post, by squiggly
Both the Diamond MX300 and Turtle Beach Montego II have alleged support for S/PDIF via daughterboards that attach via special headers, and which are rarer than the mystical Nvidia Voodoo6 6500 with hardware T&L and DX8 support.
Does anyone know if it's possible to hack a generic S/PDIF bracket with RCA and TosLink jacks onto either of the above cards using tricks like Phil recently demonstrated with the SB Live!? Is it surely a matter of finding the right pins that correspond to pins on the brackets, or do the daughterboards do more that is required for this to work?
https://youtu.be/rVNSyRAwVXs
Also, does anyone know of a good DAC with more than three inputs? The following is almost perfect, but something almost exactly the same but with 4 digital inputs would be pretty much spot on.
https://www.cambridgeaudio.com/en/products/hi … ma/dacmagic-100
Reply 1 of 5, by ZanQuance
[Montego II I2S jack]
[2][4][6][8]
[1][3][5][7]
pin 6 is your S/PDIF output
Use the Montego2 Quadzilla drivers instead and then unmute the S/PDIF playback output on the card and it works fine.
Reply 2 of 5, by squiggly
ZanQuance wrote:
[Montego II I2S jack] [2][4][6][8] [1][3][5][7] […]
[2][4][6][8]
[1][3][5][7]
Cool. I wonder if the mx300 is that simple...it has a big parallel port at the back. Its my preferred vortex2 currently.
Reply 3 of 5, by squiggly
Silly me looks like most SQ2500s give you a choice of RCA or optical out right on the card itself. I wonder what the driver software is like for them.
Reply 5 of 5, by maverick85
RogueTrip2012 wrote on 2018-04-19, 23:44:
hi, whats the pinout to get dvd digtal out to this card? i would like the cleanest cd audio from games
ASRock 98
Win98SE Desktop
ASRock
Intel Core 2 Duo E8400 3.0GHz
1 x 512MB 667 MHz DDR2
Soundblaster SB0100 + Altec Lansing ADA885
ATi Radeon X800XT 256MB GDDR3
1 x SATA 120GB HDD
1 x SATA DVD-RW
