Reply 60 of 129, by dreamblaster
Artigkar wrote:
What does that red button looking thing do?
haha don't push the red button... 🤣 it resets the sound chip.
For example if a game crashes and this causes hanging notes, you can press reset
This can also be handy for testing, during driver development.
Thanks for your support !
Reply 61 of 129, by bjwil1991
It resets the Dreamblaster S2P if you accidentally rebooted or powered off the machine when playing a DOS game instead of exiting the game properly to stop the hanging music from playing.
Reply 62 of 129, by Scali
Very nice!
I think this device is especially interesting for people developing new retro-games for DOS. They can add General MIDI support for this device easily, and anyone with a vintage machine with a printer port can enjoy great sound quality at low cost. I think it's pretty awesome how well it works even on my PCjr. There's no other way to add MIDI support to that machine.
Reply 63 of 129, by jaZz_KCS
Very much looking forward to this one!! This will be handy especially for the Win 3.1 game era. I have been waiting for something like this to add way more games to my retro laptops that run under Win 3.1 😀
Reply 64 of 129, by dreamblaster
I tested some S2P production batch boards, and they work great !
On the software side, I've been testing the new softmpu /MT32 mode today, with legend of kyrandia.
The music translates pretty well, the sound effects not.
It is certainly better than pc speaker 🤣
Here's the video of this experiment : https://youtu.be/AP66yWq6ZoQ
Reply 65 of 129, by keropi
nice one!
btw it is expected that the sfx fail since the game uploads new sounds to the mt32 , this function is not supported on anything else other than the mt32 and variants
Reply 66 of 129, by dreamblaster
keropi wrote:
nice one!
in the game setup, if you select MT32, it uses this for both music and sound.
would you know a way to config MT32 for music only ? (and for example use pc speaker for sound effects ?)
Reply 67 of 129, by keropi
sadly I don't think that's possible - unless someone hacks the sound drivers or something like that...
Reply 68 of 129, by dreamblaster
Here is Betrayal at Krondor, on a 386-dx 40 with all sound through the S2P on the parallel port, in general midi mode : https://youtu.be/_Fy7yxpoXOs
For general midi, the sound effects are fine, of course 😀
Reply 69 of 129, by dreamblaster
Available now in the webshop : https://www.serdashop.com/S2P
Compatible with the special version of SOFTMPU from https://github.com/pdewacht/softmpu
Considering the development of a patcher as well.
USING SOFTMPU: DREAMBLASTER S2P MODE
Run SoftMPU specifying the parallel interface to be used and the base port
address of the MPU-401 interface, e.g.
SOFTMPU.EXE /MPU:330 /OUTPUT:LPT1
To enable MT-32 compatibility, add the /MT32 switch to the command line, e.g.
SOFTMPU.EXE /MPU:330 /OUTPUT:LPT1 /MT32
A Sound Blaster base port address and IRQ can optionally be specified if
MPU-401 interrupts are required.
Reply 70 of 129, by dreamblaster
an S2P patcher will be available soon.
First success with doom ! 😀
The attachment DSCN2705.JPG is no longer available
Reply 71 of 129, by dreamblaster
3d printed enclosure for S2P -- prototype
Any suggestions ?
The attachment S2P_enclosure.jpg is no longer available
Reply 72 of 129, by dreamblaster
and in black..
The attachment S2P_enclosure_black.jpg is no longer available
Reply 74 of 129, by dreamblaster
another iteration ...
with easy access for reset-button
and in red again
The attachment S2P_enclosure_red_button.jpg is no longer available
Reply 76 of 129, by dreamblaster
OK... GO!
Reply 77 of 129, by appiah4
That is pretty amazing. Will there be an X2P version as well, out of curiosity?
Reply 78 of 129, by dreamblaster
Not planned at the moment.
I started design of MIDILPT --> parallel port MIDI interface
which would be more commonly usable, also with MT32 (throught softmpu).
Reply 79 of 129, by root42
I love it. Do you think it would be possible to create an ISA version as well? 8 bit card with Keystone ISA bracket?
YouTube and Bonus
