The mirrored ports are still handy as it cuts down on the number of pass-throughs needed. If you could find a way to cram on a MIDI-IN, I can think of a bunch of applications it would be great for - using a '90s laptop as an OPL3 sound module for example, or sending a MIDI clock between two machines for sync.
dreamblaster wrote:How about this feature ?
now that there's a CPU, considering to send 'all notes off' on bootup
--> this will allow to shutdown midi hanging notes by pressing reset.
Yeah a kill switch is always handy, I haven't run into a hung note in my own setup in a while but it's nice to have a clean way to zap them.
dreamblaster wrote:Also will try to keep the interfacing compatible with S2P
--> same pinout, same drivers 😀
That would be sweet, that means I could essentially start with a Win9x port of the version of SoftMPU for S2P & support both devices. I found a VxD guide with some sample code online and it doesn't seem too complicated. I'm relatively new to Win9x coding though; will be a great way to expand my range. 😀
