First post, by Intel486dx33
I don't know what is wrong.
It was working fine before.
New install of Win98se.
I have a Media Vision Spectrum Pro Audio PAS16P
Used Win98se default Media Vision drivers which usually work fine.
Device manager show PAS16 is working fine.
What is happening:
When the PAS16 play audio it plays with a high tone and plays really fast.
Does anyone know what is wrong ?
    472.74 KiB
Reply 3 of 7, by Tenorman
This is an interesting card. I've never seen a PAS16P that is missing the LMSI connector and controller chip before. Almost like a PAS16LL.
I agree that the -5v rail is the likely issue, but these cards are also speed sensitive and will have problems if you are trying to use them in anything faster than an original Pentium.
[Compaq Presario 633 | DOS 6.22 / Win 3.1 | DX4 100 Overdrive | 28M RAM | SB16 CT2770A | SPEA Media FX (Soundscape S2000) ]
[GA-6BXC R2.0 | Win98SE | Via C3 Ezra 866 | 384M RAM | TNT2 32M | Voodoo2 8M | SB32 CT3670 | Ensoniq Soundscape Opus]
Reply 5 of 7, by cyclone3d
Intel486dx33 wrote:
Is it the Power supply that's the problem or motherboard not supplying 5v to the ISA slots ?
I am using a 500 ATX PSU.
If it is the fact that the power supply doesn't have a -5v (negative 5 volt) output, you can get an adapter on eBay that adds the -5v.
https://www.ebay.com/itm/NEW-6-ATX-24PIN-NEW- … SA/251854771572
And it could be speed related as well.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 7, by Intel486dx33
Yes, I put the PAS16 back in my AMD 5x86-P75 Overclocked @ 160mhz. computer and it works great with an AT power supply.
I really like the sound of the PAS16P
Running Win95c with Vanilla Media Vision drivers.
    110.99 KiB
    PCchips M918i motherboard.
    1.1 MiB
Reply 7 of 7, by bristlehog
bristlehog wrote:
Your PSU lacks -5v rail. This soundcard needs it to operate properly.
May be either or both issues. You have to read your PSU and motherboard specs.
Hardware comparisons and game system requirements: https://technical.city
