DOS drivers for ESS688?
First post, by Red_Machine
I just have the 3.1 drivers installed for Windows, but a few games I've tried won't let me use Sound Blaster emulation because they don't detect the appropriate environment variables like "SET BLASTER". I was wondering if there was a DOS driver I could install that would enable this.
Reply 2 of 14, by Red_Machine
Thank you, but even though there's one that says "ES688 Audiodrive Full install for Dos", it's actually for the ESS968 and doesn't work. I also wasn't able to find a compatible driver in the "ESS ISA cards DOS, Win 3.x drivers" download either.
Reply 3 of 14, by dr_st
I don't think there is a driver for the ESS688. It's non-PnP, just assign the resources to it and it's... there.
Reply 4 of 14, by NJRoadfan
I have the original install disks for the ESS688. I'll get them posted later today. The card requires a setup program run at boot to change the default IRQ and DMA channels. The defaults on power-on are to use IRQ 7 and DMA 1, the same as early Soundblaster cards.
SET BLASTER=A220 I7 D1 T4 should be enough to get the card working in DOS without the driver. Make sure your parallel port isn't on IRQ 7!
Reply 5 of 14, by tpowell.ca
Some versions don't have jumpers and require initialization (eg: exceedingly rare Compaq-branded cards like mine).
I can't remember where I got mine and I'm not home, but maybe try these:
http://vogonsdrivers.com/getfile.php?fileid=1461&menustate=0
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 6 of 14, by NJRoadfan
Those Edison "Gold" disks should be the same as the Soundplus-16 disks I have for my old 688 based card (Disk 2 had the Voyetra Windows tools). I'd love to see the box for the Edison card, it was likely equally campy in design!
Reply 7 of 14, by keenmaster486
Try SET BLASTER=A220 I5 D1 T4, and if that doesn't work try changing the IRQ to 7 or the DMA to 3 or both.
I.e. just try things until it works. It's not rocket science.
World's foremost 486 enjoyer.
Reply 8 of 14, by Red_Machine
This is in a laptop, so there are no jumpers for me to change. I tried adding SET BLASTER to AUTOEXEC.BAT previously, and nothing would come up on boot, probably because it lacked the files necessary to use the SET BLASTER command.
Reply 9 of 14, by gdjacobs
The Edison disks also should have a TSR required to enable MPU-401 support.
Reply 10 of 14, by Red_Machine
I checked out the Edison drivers, and they're actually Windows drivers so I can't install anything.
Reply 11 of 14, by keenmaster486
This is nonsensical. How are you trying to use SET?
Reply 12 of 14, by Red_Machine
Just the standard "SET BLASTER=A220 I7 D1 T4" in AUTOEXEC.BAT
Reply 13 of 14, by NJRoadfan
The program ESSCFG.EXE on the 1st disk is what you want to run to configure the card. ESSVOL.EXE is a mixer program for DOS as well.
Reply 14 of 14, by Tenorman
I'm not sure what model of laptop you are using, but I have a Pentium 75 Toshiba Satellite with the same sound chip. The resource settings are configurable in system's BIOS. Have a look there.
In order to play DOS games, all you really have to do is configure the BLASTER environment variable to match these settings. You can optionally run ESSVOL.EXE to configure your mixer settings in autoexec.bat as well, but this isn't mandatory.
[Compaq Presario 633 | DOS 6.22 / Win 3.1 | DX4 100 Overdrive | 28M RAM | SB16 CT2770A | SPEA Media FX (Soundscape S2000) ]
[GA-6BXC R2.0 | Win98SE | Via C3 Ezra 866 | 384M RAM | TNT2 32M | Voodoo2 8M | SB32 CT3670 | Ensoniq Soundscape Opus]
