First post, by nathanm1991
Hi there I don't know if this has been Covered already and Apologies if so 😊
I Installed a PCI 128 Soundcard as my SB Live! CT4780 was Giving me all Kinds of Issues both Under Dos Mode and in Windows 98SE. I Installed the Card Absolutely Fine and Also installed the EXE that allows the Driver to Work under Dos Mode. Well the Card works Absolutely Brilliant under Dos but it has Altered the Restart in MS-Dos Mode.PIF that philscomputerlabs.com Provides. I have lost the Option Menu for Extended Memory, CD-ROM and Mouse.
I can Navigate to the Drivers folder and start the Mouse Executable Manually which is Fine but I would like to be able to use it how it was before but with the PCI 128 also starting within Dos Mode
I hope this Makes Sense and thank you 😀
