Identify the card in this picture?
First post, by cyclone3d
What could the card in this pic be? The one with the RCA connectors. I already have a pretty good idea, but want to see what other people say.
The attachment s-l1600.jpg is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 26, by Grzyb
Some AV card?
Seems to have S-Video IN and OUT, and those RCA connectors are audio L and R.
Reply 3 of 26, by cyclone3d
@Tiido - I think that is what it is, but from what I could find it could also be a MPU 401/AT unless you know otherwise. Do you have a MPU 401/AT?
If so, are the arrangement of connectors exactly the same?
I couldn't find a picture of a bracket/connectors of the MPU 401/AT.
YMF7x4 Guide
Reply 4 of 26, by derSammler
Just ask the ebay seller, he should know what he's selling.
Reply 7 of 26, by cyclone3d
Heh... I'll just have to wait till it gets here to find out for sure.
The only thing that points me towards the SCC-1 specifically is that I think the number that they posted with it matches the serial number style and length.
YMF7x4 Guide
Reply 8 of 26, by oeuvre
might be the vaunted creative sound blaster AWE128!
Reply 9 of 26, by derSammler
So you already bought it? Expect some very heavy damage by battery leakage.
Reply 10 of 26, by imi
that's the first thing I spotted too, good thing it's a desktop case, so damage to the cards is probably minimal if any.
Reply 11 of 26, by derSammler
Alkaline solution from a battery can spit across quite badly. I've seen (and had) systems where stuff on the other end of the case had rotten away, even though there was no direct path taken by the alkaline solution to that spot. Also, even desktop cases are often stored upright, as they take less space that way. So let's wish him luck that the card in question took no damage.
Reply 12 of 26, by cyclone3d
I've gotten a few systems that have battery damage before and none of them affected the installed cards at all.
That being said, the seller said that the keyboard port works and the system responds to ctrl-alt-del so I am guessing any damage to the motherboard is minimal.
I'll post back with pics and more info once I receive the system.
YMF7x4 Guide
Reply 13 of 26, by oeuvre
might need a good cleansing!
Reply 14 of 26, by Miphee
Be careful with cleaning.
This 286-NEAT was working fine with all that damage but went to hell as soon as I cleaned all the gunk up. The traces were hanging by a nanothread and I succesfully cleaned them away. It took a lot of effort to repair all the traces after my handywork.
Reply 15 of 26, by oeuvre
how does one remove corrosion?
Reply 17 of 26, by Miphee
I use vinegar and baking soda. Sometimes the traces under the protective enamel are long gone and only it's outlines exist.
It's best to make high resolution photos before cleaning to preserve the original trace layout in case you need repairs later.
Reply 18 of 26, by oeuvre
Thanks guys!
Reply 19 of 26, by cyclone3d
So.. got the system today. It works and booted to a DOS command prompt once I entered the HDD parameters into the BIOS.
It looks like this system was used for producing music. There are some MIDI files that appear to have been authored on this system but I will know more once I actually have the battery corrosion fixed and an external battery installed. Very interested to see if anything points me towards anything that is known.
It also has Windows 3.1 on it.
And here are some pictures:
Leading Edge 386DX-33 system. The seller listed the manuals separately so I have them on the way now... kinda sucks they weren't included but whatever.
The shipping was kinda crazy high, but from what I could tell, the seller had it packaged up by Fedex. It was packaged extremely well so I guess it was worth it to keep it from getting damaged at all.
The attachment case.jpg is no longer available
The card in question is an SCC-1. Any way to tell if it is the original or the newer one with the added instuments by just looking at it?
The attachment SCC-1_front.jpg is no longer available
The attachment SCC-1_back.jpg is no longer available
Pics of the leaking battery. From what I can tell it only ate away at the ground plane covering around where it was leaking. All other traces look A-OK. 😀 I have already cleaned it with vinegar and am waiting just a bit more before I rinse it off and then remove the battery. Looks like there is a hookup for an external battery but I will have to make sure once I remove the battery.
The attachment battery_1.jpg is no longer available
The attachment battery_2.jpg is no longer available
YMF7x4 Guide
