Rack recommendations for Midi devices etc.?
First post, by skel2raw
Hi guys,
I have piling my SC-55, MU-80, etc. all the equipment piling up on my desk. However, I would actually like to install them all on some sort of an open rack so that they look nicer and more organized and don't move when I press buttons or plug in and out cables.
I saw today this video from LGR:
https://www.youtube.com/watch?v=rEMqLmqsLaQ&t=315s
In minute 4:48 he is showing a rack on his that which actually looks pretty nice. Do you guys know how those racks are called and where I can find this kind of racks?
Thx!
Reply 1 of 21, by cyclone3d
Huh... that looks like a little 2-post rack or a wall mount network equipment rack that he just set on his desk.
You can buy rack posts by themselves so you can make whatever you want.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 21, by skel2raw
Ah I see... and do you know, how I can manage to mount my SC-55 etc. on tha wall mount? Is there some special sort of mounting stuff?
Reply 3 of 21, by imi
what you're looking for is a rack shelf, while there is one specific for the roland devices (roland rad-50 for example) you can just use any usually.
the rack itself is just a normal 19" rack.
Reply 4 of 21, by j^aws
skel2raw wrote on 2020-03-16, 21:20:
There are many types of rack cases/ enclosures. They all have standardised widths. They can be mounted on walls, desks and left on the floor.
Look for 'audio racks'.
The height of equipment to install is standardised aswell. They are measured in units of ' U'. For example, 1U, 2U, 3U, 4U etc.
So for a typicall Roland SC55 desktop unit, it would measure 1U in height, and half-width in width.
What you need is a 1U half- rack adapter to add to an audio rack unit. Then mount an sc55 into it, for example.
Most professional gear however are standard widths, not half-width, but mostly vary in U heights, typically 1-4 U.
EDIT: 19" audio racks, specifically.
Reply 5 of 21, by dionb
Lots of places to get those. I have two 4U audio racks on my retro desk supporting a plank with monitors. I bought mine ("Millennium Steel Box 4") here:
https://www.thomann.de/intl/studio_racks.html
Thomann ships all over Europe, elsewhere shipping probably becomes an issue, but there will be similar shops.
Reply 6 of 21, by imi
I'm also using the millenium steel box ^^
Reply 8 of 21, by kolderman
Don't you need to get rack-specific modules? I thought most modules came in stand-alone and rack-mount versions.
Reply 9 of 21, by derSammler
Roland SC and Yamaha MU series were rack-mountable by default. But you need the base plate which was attached to the unit's bottom to rack-mount them.
When using a rack-mount shelf, however, it's no issue.
Reply 10 of 21, by Dimitris1980
This is a very nice theme.
From the top:
Yamaha MU50
Roland Sound Canvas SC55
Roland Sound Canvas SC88
Roland CM64
Roland MT32
What type of rack do i need for the above 5 units? On desk, not on wall or floor.
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower (x2), Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Reply 11 of 21, by Dimitris1980
Well, i forgot to mention that above the devices i have an audio switch and a mixer about the same height.
- Cyrix 120
- Atari 1040 STF
Reply 12 of 21, by BloodyCactus
its standard 19" rack stuff. amazon, ebay, everyon sells it. you just need some rackshelves to sit the midi modules on since they are half width.
Reply 13 of 21, by Dimitris1980
BloodyCactus wrote on 2021-03-25, 20:34:
Thank you.
- Cyrix 120
- Atari 1040 STF
Reply 14 of 21, by Dimitris1980
I see that there are lot of 19" racks but i think is not that simple depending the stuff someone owns of course. I have 5 devices with different dimensions. The Roland Sound Canvas SC55 and the Yamaha MU50 seem to have the same width and height so they can be put the one next to the other. The Roland Sound Canvas SC88 is higher. Roland MT32 and Roland CM64 have bigger width than canvas. It seems that the width of the 19" rack is 49cm. Unfortunately i cannot put other device next to the Roland CM64 or Roland MT32.
- Cyrix 120
- Atari 1040 STF
Reply 15 of 21, by BloodyCactus
well.. of course. the mt32 is not a rackable device. sc88 is what, 2u tall instead of 1u. some things are just not designed to be racked (mt32/cm64 etc).
you just put them on a shelf on their own as either 1u or 2u tall and it is what it is.
Reply 16 of 21, by imi
also keep in mind that the MT-32 does not fit in a single rack height unit, it's a little bit taller, the SC88 is 1.5u high, so you could solve that by having the MT-32 on a shelf offset above the SC88, so make sure to get a rack with offset holes, so 3 mounting holes per rack unit on each side.
same probably goes for the CM-64, but I don't have one of those unfortunately, so I can't tell you for sure, but you can just stack the CM-64 and MT-32 on a single shelf then.
Reply 17 of 21, by Dimitris1980
I think i will stay as i am now. 😀
- Cyrix 120
- Atari 1040 STF
Reply 18 of 21, by imi
yeah, don't really need a rack for just a few of them ^^ they stack just fine
Reply 19 of 21, by Dimitris1980
imi wrote on 2021-03-29, 09:01:
Thank you for the information. I will keep as it is.
- Cyrix 120
- Atari 1040 STF
