First post, by genau_der
Hi!
I have this particular soundcard, see here.
It's basically working with the ES1868F drivers from Phil's website, but the volume is extremely low.
Turned the volume all the way up in the DOS mixer app, in Windows 98 SE also everything on max level.
Tried the jumpers behind the output jack in the other position, but then it's completely quiet.
Also tried multiple DOS and Windows Games and MP3 Playback in Winamp. I can barely hear anything in usual volume knob position, when I turn my amplifier all the way up it's still quite low volume but with lots of noise.
Should I maybe try to replace the capacitors? They're still looking good, not bulged or leaked, but who knows.
Any suggestions appreciated!
Don't want to give up on that one too early.
Thanks!
