Reply 400 of 491, by root42
- l33t
matze79 wrote on 2020-05-15, 08:12:tracker.jpg
Something weird is going on 😳
awesome. who made that?
Jan is working on it ^^
Next Step:
digging into programmable logic devices, adding more features without rising the chip count and board complexity.
matze79 wrote on 2020-05-18, 18:10:Jan is working on it ^^ […]
Next Step:
next_step.jpgdigging into programmable logic devices, adding more features without rising the chip count and board complexity.
It's a GAL!
matze79 wrote on 2020-03-10, 19:11:Here is a Preview on Almost-Release Canidate R1.3,
Full reroute, with some optimizations by dreamblaster in KiCad to allow machine assembly, and better hand assembly.
Is the project ready? Where to buy?
the card will be avaible from Serdashop, all is preparing for launch!
Watch out for News! I guess it will be in late Summer.
Thanks
further progress.. Card is finalized, except for metal bracket.
Efforts continue, prototyp bracket is fitting.
I struggle bit finding blank slot covers with no grooves or weird plating that breaks when drilled.
Keep listening! 😀 we`re going final.
Thanks to Dreamblaster again for all efforts / help / support!
Also Tandy Tracker is coming soon:
Since unfortunately there is no drill rig/drill machine available, it is somewhat inaccurate.
Had to file the holes in by hand.
Looks pretty good to me.
Hi.
Of course Mod Master support it as well 😀
But as I have real tandy I don't need this card 😀
I did a video on Tandy music:
https://youtu.be/PKg762dr4kE
We really need more tandy .vgm files.
Anyone motivated to do it using the modified dosbox ?
You can find at least some on vgmrips:
https://vgmrips.net/packs/system/tandy-corpor … tion/tandy-1000
I know. This is all I have unfortunately 🙁
Driver issues almost ruled out, thanks to Dragonsphere compatibility now increased a lot!
Tested so far:
- Ultima 6
- Stunts
Playing without any issues now!
Testing Release ( Only Tandy Card @ 2C0, note this is Testing VERSION only!)
command:
tndy C0-C7 2C0 nosb tandy
No fix yet for tndlpt.
Please try it out and report!
matze79 wrote on 2020-10-18, 11:35:Driver issues almost ruled out, thanks to Dragonsphere compatibility now increased a lot! […]
Tested so far:
- Ultima 6
- StuntsPlaying without any issues now!
command:
Just tried, works for the card, just like TNDLPT 0.14 for the LPT dongle.
Now we just have to figure out how to solve the noise channel issue.
matze79 wrote on 2020-10-18, 11:35:No fix yet for tndlpt.
For Serdaco TNDLPT, the 0.14 software version by pdw released a few days ago also does the trick, as per my suggestion on fixing games that wrote to 0C1h.
Ah there is new tndlpt tsr version, did not try it yet 😀
Anyone interested into a Card ? maybe i do another run until Dreamblaster is ready.
There is still delay which is really annoying.
I really was hoping to get this thing into to Store to get it public avaible in Time.
But it seems there are further Issues with this.
I'd be interested. Sounds like a good match for my 286 AT clone.
~The Creeping Network~
matze79 wrote on 2021-01-13, 23:03:Anyone interested into a Card ? maybe i do another run until Dreamblaster is ready.
I would definitely be interested in a card if you do another run. 😀
If this is still happening I would definitely buy one.
This card is not 🤣
