Reply 60 of 377, by Falcosoft
- Oldbie
SC55 Sound bank of VSC 2.x has "226 Tones + 9 Drumsets". That coincides exactly with what Microsoft GM.DLS file has - i am attaching picture to show that.
I am able to find only 217 tones (216 on my picture as I count from 0) - see the attached picture. That's another unexpected thing - maybe I missed something obvious - anyway as next step I will need to compare my list and the list I got from MS GM.DLS to see which 9 "tones" I am missing and why, i.e. where they are to be found in SC55 VSC 2.x Sound Bank.
I do not want to be a party killer but you have not found 217 tones. Everything on your picture starting from '169: High Q' are part of the 9 Drumsets and not the 226 tones. If you inspect the names carefully you should recognize the individual drum sounds that make a drumset (such as Hi-hats, Cymbals, Kick drums, Snares, Congas etc.).
According to GM specification (and also in GS) in case of channel 10 every single note represent an individual drum sound, not the same sound/instrument on different pitches.
In GM (and in GS Standard drumset) these individual drum sounds are the following ( they can be reached from note 35 to note 81):
35 Acoustic Bass Drum
36 Electric Bass Drum
37 Side Stick
38 Acoustic Snare
39 Hand Clap
40 Electric Snare
41 Low Floor Tom
42 Closed Hi-hat
43 High Floor Tom
44 Pedal Hi-hat
45 Low Tom
46 Open Hi-hat
47 Low-Mid Tom
48 Hi-Mid Tom
49 Crash Cymbal 1
50 High Tom
51 Ride Cymbal 1
52 Chinese Cymbal
53 Ride Bell
54 Tambourine
55 Splash Cymbal
56 Cowbell
57 Crash Cymbal 2
58 Vibra Slap
59 Ride Cymbal 2
60 High Bongo
61 Low Bongo
62 Mute High Conga
63 Open High Conga
64 Low Conga
65 High Timbale
66 Low Timbale
67 High Agogô
68 Low Agogô
69 Cabasa
70 Maracas
71 Short Whistle
72 Long Whistle
73 Short Guiro
74 Long Guiro
75 Claves
76 High Woodblock
77 Low Woodblock
78 Mute Cuica
79 Open Cuica
80 Mute Triangle
81 Open Triangle
