First post, by zhang760301
I need ct4620 driver original cd disc, who have please provide a bit, thank you!
Reply 1 of 20, by SirNickity
I might -- I have one of the (I think?) original retail releases with gold jacks. But, IIRC, it wasn't sold as a Sound Blaster Live! Gold. I'll have to check and see what my model is, and if I can find the original discs. I know I've seen at least one of them lately...
Reply 2 of 20, by cyclone3d
Do you have any idea what the exact CD ID is?
There are quite a few different Live! CDs available on vogonsdrivers.com
Edit:
I might have an original CD laying around. I'll have to check this evening.
Also found this site... convert Live! to Live! 5.1
http://ixbtlabs.com/articles/livetolive51/index.html
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 20, by zhang760301
Thank you for your help, CT4620-SBLive! (PCI \ VEN_1102 & DEV_0002 & SUBSYS_00211102) is Sound Blaster Live! Standard Edition.
Reply 4 of 20, by cyclone3d
zhang760301 wrote on 2020-02-20, 01:19:
Do you want the oldest CD available that supports the CT4620, the newest, or something in-between?
I'm checking the CD images on vogonsdrivers.com now.
The CDs I have (Install and Application/DEMO) are newer than the original CD but it does support the CT4620.
Edit:
Same as the Install CD I have - supports - CT4620, CT4670, CT4760, SBlive motherboard, CT4850
http://www.vogonsdrivers.com/getfile.php?file … menustate=43,36
Another that supports the same cards.. just more languages:
Older one that only supports the CT4620 and CT4670:
Either way, once you do the initial install, you will want to update to the latest and greatest drivers available. You can even force install the Audigy drivers for improved audio quality... might depend on the model of the EMU10k1 chip but I doubt it.
That is one of the things I always did back in the day because the Audigy drivers were better.
The application CD I have is a bit different than the ones that are already on vogonsdrivers. I'll get it uploaded when I get a chance.
YMF7x4 Guide
Reply 5 of 20, by zhang760301
I need the oldest original driver CD of CT4620, and I am looking forward to it.
Reply 6 of 20, by cyclone3d
zhang760301 wrote on 2020-02-20, 10:56:
What about the one in the bottom link I provided above?
Other than that, if you absolutely must have the original one, then you are going to either need to find somebody that has a sealed boxed CT4620 or know what the exact text of the DISK.ID file is for the Install CD and the Applications CD.
The CDs don't say what card they came with on the label.
YMF7x4 Guide
Reply 7 of 20, by SirNickity
Looks like you might indeed have the same version I do. I have the add-on digital I/O card connected with a ribbon cable, with the mini-DIN digital outputs and MIDI -- so, similar if not same model card. The PDF might be a little bit later revision than my original CDs. I'm trying to remember whether "LiveWare" was a thing yet. Some of the applications screen shots look familiar, but I used that card primarily for probably more than five years, and of course downloaded driver updates along the way.
Will have to find all of the CDs then...
Reply 8 of 20, by SirNickity
I found the second disc, with all the extra applications on it. Here's a pic of the disc itself:
Still looking for disc 1 with the drivers and core applications.
I can post this on a Google Drive share, or if someone wants to put it on Vogons Drivers, that would be fine by me.
Reply 9 of 20, by script-fu
I have al three disc's...
Creative Sound Blaster Live CT4620 PCI w/ CT4660 Daughter Card.
This setup cost me $200.00 + back in 1998/99 thanks to Maximin PC. I will need to read up on how to donate the Cd's to the Driver Library. I'm sure a thread here explains how to do this.
Gb GA-6BXC r.2.0 b.F4C, PIII 1.0GHz SL5QV, 768MB PC133, GF Ti 4200 64MB, VD3 2K, CT4760 & CT4860 AGP 2X
Abit KN8, 64 3400+ (754), 2x1GB G.SKILL PC3200, GF 6800GT 256MB AGP 8X
Abit Fatal1ty AN9 32X, 64 x2 6000+, 2X2GB PC6400, 8800 GTS 320MB x2 SLI
Reply 10 of 20, by RichB93
script-fu wrote on 2020-10-09, 00:29:
You can PM SquallStrife for a VogonsDrivers account and upload it there, or, if you post links here (e.g. WeTransfer) I can upload it on your behalf if you wish as I have an account.
Reply 11 of 20, by script-fu
Ok cool thanks for the heads up.
I just finished burning all three disks to .iso & here is what i have from the DISK.ID
DISK1
Sound Blaster Live!
SBL-CDS1D-3-US
DISK2
3rd Party Software
3PA-CDS1D-1-US
DISK3
Sound Blaster Live! Tour and Demonstrations
SBLT-CDS1D-1-US
What file do i open on Disk1 to see the different sound cards the drivers support?
Thanks for your time!
Reply 12 of 20, by script-fu
I jacked this description below from one of the listings on the vogons_drivers_dot_com website. However i'm not sure where that info below is stored in the drivers. Which file has this info in it?
Description VXD 4.06.654
CT4620 - SBLive! (PCI\VEN_1102&DEV_0002&SUBSYS_00211102)
CT4670 - SBLive! Value (PCI\VEN_1102&DEV_0002&SUBSYS_00201102)
CT4760 - SBLive! (PCI\VEN_1102&DEV_0002&SUBSYS_80401102)
SBlive motherboard (PCI\VEN_1102&DEV_0002&SUBSYS_002F1102)
CT4850 - SBlive! Value (PCI\VEN_1102&DEV_0002&SUBSYS_80511102)
Reply 13 of 20, by script-fu
Ok i found the info & here is what i have in my readme.txt
CONTENTS
DISK1
Sound Blaster Live!
SBL-CDS1D-3-US
Under the \AUDIO\ENGLISH\WIN95DRV folder, there are three *.inf files
CTMISC.INF
; Description
; This inf file contains the following device for installation
; a. Sb16 Emulation
; b. Gameport Joystick - CTL7009
; c. Gameport Joystick - PCI\VEN_1102&DEV_7002&SUBSYS_00201102
; d. SBlive! Sb16 Emulation
; Date : 13 July '98
; Revision : 1.08.000
EMU10k1.inf
; Description
; a. CT4620 - SBLive! (PCI\VEN_1102&DEV_0002&SUBSYS_00211102)
; Date : 21th July '98
; Revision : 1.14.000
UPDDRV05.INF
; Description
; This .inf files is to list out the .inf files to be
; copied over
; Revision 1.02.000
; Date 20th September '96
[Version]
Signature="$CHICAGO$"
provider=%CREAF%
[INFInstall]
emu10k1.inf
ctmisc.inf
DISK2
3rd Party Software
3PA-CDS1D-1-US
DISK3
SBLT-CDS1D-1-US
END
Reply 14 of 20, by script-fu
I gathered all the .VXD versions as posted below. I'm beat tho so i will get the finial pictures of the disks and the two cards tomorrow. I will zip everything up and upload this tomorrow somewhere. File size is right around 1.20 GB
SFMAN.VXD
FileVersion 4.05.1012
InternalName SFMAN.VXD C / LegalCopyright Copyright © 1997-1998 Creative Technology Ltd. O ; LegalTrademarks SoundFont® is a registered trademark of E-mu Systems, Inc. "
OriginalFilename SFMAN.VXD # ProductName SoundFont® Manager
ProductVersion 4.05.1012 $ VarFileInfo Translation
EMU10K1.VXD
+Creative Emu10k1 Hardware Abstraction Layer
EMU10K1_DDB ÿ ÿ 0 ü ü4 VS_VERSION_INFO ½ïþ ù ù ? p: Ž StringFileInfo z 040904E4 * CompanyName Creative Technology Ltd. A - FileDescription Creative Emu10k1 Hardware Abstraction Layer
FileVersion 4.05.1017 !
InternalName EMU10K1.VXD A - LegalCopyright Copyright (C) 1998 Creative Technology Ltd. %
OriginalFilename EMU10K1.VXD . ProductName Creative Sound Blaster Live!
ProductVersion 4.05.1017 $ VarFileInfo Translation ä
CIFMAN.VXD
CIFMAN_DDB ÿ ÿ 0 Ü Ü4 VS_VERSION_INFO ½ïþ ë ë ? ¥2 p StringFileInfo \ 040904E4 * CompanyName Creative Technology Ltd. 5 ! FileDescription Creative Interface Manager Vxd FileVersion 4.05.1003 InternalName cifman.vxd G 3 LegalCopyright Copyright (c) Creative Technology Ltd. 1994-1998 $ OriginalFilename cifman.vxd ProductName Creative Audio
ProductVersion 4.05.1003 $ VarFileInfo Translation ä
Reply 15 of 20, by RichB93
Sorry for the delay -I think in the sake of completeness people would appreciate the full disc set regardless of the actual driver version, as they also contain software etc. Feel free to pop links here and as mentioned I'll happy upload them to VogonsDrivers for you 😀
Reply 16 of 20, by script-fu
RichB93 wrote on 2020-10-09, 13:57:
Cool man as I'm still setting up a google drive to drop you a link. I already took some pictures of the cards & discs. Some turned out and some didn't so the wife is going to give it a shot when she gets home. In the meantime I have been going thru all my cd books / briefcases. We call them bibles here 🤣 looking for anymore creative discs that might have come with those two cards. I can't remember how many disc came with the darn thing as it's been 20+ years since i built a PII system.
Anyway i had forgotten how many Maximum CD's I have from all three magazines. They had a Linux, Mac & PC editions of which i had all three subscriptions. Those discs are packed full with game demos & utility's but so far no 4th, 5th or 6th Creative disc... humm
Anyway i will drop a link to my google drive sometime tonight or tomorrow...
_Best
Reply 17 of 20, by script-fu
Removed links to my google!
Reply 18 of 20, by RichB93
script-fu wrote on 2020-10-09, 22:58:
@RichB93 This zip file is 803 MB
I also found an interesting driver cd for ASOUND-6. The zip file is 18.5 MB so i figured why not.
Thank you! I've compressed and uploaded the CDs to VogonsDrivers, using your readme and images. I've also uploaded the Avance Logic files too and created a quick summary of the contents.
Reply 19 of 20, by script-fu
Your welcome Rich.
Can you do me a favor and remove the links to the disc?
